2014 c7
Old Aug 7, 2021 | 10:51 PM
Napoletano1's Avatar
Napoletano1
8th Gear
Default 2014 c7
2014 C7 has anyone done an ignition upgrade? New plug wires and coils? Trying to decide which brand is best...MSD, Granatelli. Any suggestions? TIA
Old Aug 8, 2021 | 09:33 AM
Goshawk23's Avatar
Goshawk23
I went with brisk plugs and msd wires when i did my header install. I usually go with ngk plugs but opted to try another plug this time. Stock heat range. Nothing stands out to make me believe they are better than any other brand.
Old Aug 8, 2021 | 12:02 PM
Jeff V.'s Avatar
Jeff V.
Why do you feel the stock ignition is insufficient?
Old Aug 8, 2021 | 03:39 PM
Horsefly's Avatar
Horsefly
I too, went with Brisk plugs & MSD wires when I installed headers & got tuned. My tuner recommended the Brisk plugs and told me to give them a call for their recommendation. The gent on the phone wanted to know what engine modifications were done, then recommended a plug. If you go with MSD's, I'd suggest that you get plug boots as they are really close to the exhaust.
Old Aug 8, 2021 | 03:47 PM
AEK's Avatar
AEK
When I was chasing an engine problem in my 2014 C7 that was ultimately a broken valve spring, I replaced all the plugs and wires (and coils) ... with stock ones. At around 24k miles, IIRC. Haven't noticed any spark issues before or after ...
To 2014 c7
