wet Key Fob
Old Aug 22, 2021 | 03:23 PM
danm1's Avatar
danm1
Default wet Key Fob
I accidently left my key fob in my pants pocket and it went through our clothes washer at home. I found the key fob before the pants hit the dryer. Surprisingly, the key fob worked while soaking wet, nonetheless, I disassembled it and let the parts dry out. It appears to work now but will it be dependable in the future? I have my spare fob but perhaps I should have another made just in case this one craps out someday? Thanks in advance for any input into this issue.
Old Aug 22, 2021 | 04:28 PM
pit-man's Avatar
pit-man
I pulled the key out of mine for air and put the fob in a jar of rice for 2 days. No issues at all.
Old Aug 23, 2021 | 12:45 AM
Avanti's Avatar
Avanti
If it is working consistently since it's now dry, I'd put in a new battery while at it and use.
Old Aug 23, 2021 | 07:07 AM
Internets_Ninja's Avatar
Internets_Ninja
The key fobs have a rubber gasket that are supposed to keep water out. Not sure how effective it is but I've had my fob go through the washing machine before without an issue. It did not go through the dryer though.
Old Aug 26, 2021 | 07:31 AM
Zjoe6's Avatar
Zjoe6
As long as you dry it out, it should be fine. The rice trick always works.
To wet Key Fob
