C7 Roaring Noises
Old Aug 27, 2021 | 06:00 PM
tonyclark1's Avatar
tonyclark1
Default C7 Roaring Noises
C7 roaring noises. Sounds like tires but not sure. Anyone have any ideas????
Old Aug 27, 2021 | 06:27 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
More detail would definitely help to help you.
Old Aug 27, 2021 | 08:59 PM
tonyclark1's Avatar
tonyclark1
Well, I'm riding down the road and its either the tires or a bearing issue. Roaring noise speeds up and slows down when I speed up or slow down. It started when I went on a long trip with the car. 400 miles to be exact. Other than that that's all the info I can give. I seem to think it's the BF Goodrich tires making all the noise. I'm running 30lbs air pressure when tires are hot. Don't know for sure if it's the tires. I have had a lot going on lately with my truck also so when this started with my Corvette, it just sent me over the edge a little bit. Thanks for responding.
Old Aug 27, 2021 | 09:54 PM
Black*Death's Avatar
Black*Death
If it is a wheel bearing, it should get worse while turning..Assuming it's the front tires? I believe the passenger side is louder in a left turn and vice a versa for a driver's side wheel bearing?
If able...jack up the car and spin the tire...sometimes a loud grinding noise that stops the wheel spinning fairly quickly could be a wheel bearing
Old Aug 27, 2021 | 10:29 PM
oregonsharkman's Avatar
oregonsharkman
A few questions:
1) Have you had the car for a long time and now suddenly there is a change and it's making the roaring noise? Or have you only owned the car for a little while and are now noticing it?
2) Are you driving on rough pavement at highway speeds? The tire noise on rough highway at speed can be pretty loud
3) Did you change tires lately?
If none of the above, you should take it to a shop and have it looked at.
Old Aug 27, 2021 | 10:40 PM
tonyclark1's Avatar
tonyclark1
I have had the car for almost a year and didn't notice it until I drove the car on vacation. I have not changed the tires. I know that there are rough patches of interstate and I have heard that before. It's not rough hgwy or roads, it's different. Seems like the tires. Can someone tell me what were the original tires on a 2015 LT1 Stingray Corvette. The tires on it now are BF Goodrich. The original owner said these are the original tires. When I get the a chance I will lift the car and check the wheel bearings by spinning the tire. Thanks.
Old Aug 27, 2021 | 11:43 PM
DrivesWithTwoFeet
Factory tires are Michelin Pilot Super Sports ZP run flats. BF Goodrich, I believe, doesn't make a run flat tire that fits a C7. Do you feel any rhythmic vibration in the steering wheel or dead pedal at highway speeds?
Old Aug 28, 2021 | 06:54 PM
tonyclark1's Avatar
tonyclark1
I don't know what you mean by dead pedal at hgwy speeds?? I have noticed that the roaring is rhythmic and speeds up or slows down when I do.
Old Aug 28, 2021 | 07:17 PM
DrivesWithTwoFeet
The dead pedal is where you rest your left foot. If you feel vibration have the wheels balanced, tires checked for internal damage and if wheels are bent.. If that all checks out I would take the car to the dealer and go for a test drive with the tech to describe and hopefully replicate the issue. Good luck for a quick repair.
Old Aug 29, 2021 | 01:49 PM
Bill Dearborn's Avatar
Bill Dearborn
The front and rear wheel bearings will sometimes make noise when they are too loose. Drive the car at about 30 mph and move the steering wheel back and forth (keeping in lane but using all of the lane) and listen for differences in sound.
One issue you might have is it seems you may have your tire pressure too low. The tires should be set to 30 psi Cold as described on the door sticker and OM.
Bill
Old Aug 30, 2021 | 12:48 AM
Avanti's Avatar
Avanti
I'm saying the tires, most likely. Have you actually looked at the tires? Are they worn... any of them, and/or in a particular pattern? Since you seem to have no idea about the tires (certainly not original, nor did the seller), you might look for a production date-code on them to interpret how old, and hard they likely are.. Also, they should be at 30# cold, all the way around. You may well find that the edges are "scalloped" contributing to noise, as well might be an issue of tire balance... or, lack there of. That is I'm thinking you've not had checked. My suggestion is to eliminate possible tire problems first, before looking for other, much less likely issues. All the best.
Old Aug 30, 2021 | 07:46 PM
tonyclark1's Avatar
tonyclark1
Looked at tires today. Inflated to 30psi cold. No cupping or uneven wear. Did not get to road test today due to rain. Forecast says rain likely the rest of the week so I don't know when I will get to test. Tires were balanced when I put new rims on the car. It didn't roar back then and I don't know why it would start doing it now.
To C7 Roaring Noises
