Strange shift sound after tune
Old Sep 14, 2021 | 06:35 PM
CrazyKZ-777's Avatar
CrazyKZ-777
Default Strange shift sound after tune
I just got put on American long tube headers with CAI and a tune on my 2017 Z06. When I'm in Sport or Track mode (the loudest exhaust mode) I hear a strange sound when shifting gears normally, not WOT. I can only describe it like a sneeze!
I didn't get a trans tune. Is this the exhaust opening up as it shifts? Has anyone else experienced this? If so, any way around it?
I like (sometimes) being able to go into stealth mode with the exhaust, but I've noticed that when I back off on the peddle to cruise, it closes the exhaust. NO! I want it open while on the road. I don't have headers to sneak around down the street. I think I want it wide open ALL the time. I guess I need to forgo the electronic system and install a manual NPP. I haven't upgraded the exhaust yet. I used to have on my C6 headers and Corsa Extremes. That combo was nice. I had no NPP on the C6. What do you suggest for the C7?
Old Sep 15, 2021 | 02:56 PM
CrazyKZ-777
I ended up pulling the fuse for the NPP system to force the flaps open 100% of the time. Who would want to not hear the loud exhaust, right? So, it actually did help the abruptness of the shifting noise. I guess it was forcing the flaps open, then closed when shifting. That can't be normal. I'm going to keep looking into this, but wanted to give an update and would love to hear if others have the same issue or not.
I will probably invest in the M2W system in case I wanted to make it quieter rolling in at midnight sometimes. Any users of the Mild to Wild switch?
Old Sep 16, 2021 | 11:39 AM
C7&7's Avatar
C7&7
Yea the flaps will blow open if you're hammered down. Why didn't you get the trans tuned also? A tune is a tune...
Old Sep 16, 2021 | 11:59 AM
CrazyKZ-777
I'm referring to just simple normal driving, not WOT.
It's my understanding that starting in 2017 (my year) GM locked the trans so it makes it harder to do a trans tune.
I didn't do the trans tune because of the added cost. I'll have to check and see what that cost is and also see if it would even fix this issue.
With the flaps wide open now (by pulling the NPP fuse) it does sound some better, but it's still a strange sound. Almost like it's shifting way too early and not power shifting. When I paddle it, I never hear that sound.
Old Nov 11, 2021 | 10:50 PM
CrazyKZ-777
As an update, a few weeks ago I got a transmission tune and that sound went totally away! The car was shifting way too early. It’s perfect now.
Old Nov 12, 2021 | 11:42 AM
Internets_Ninja's Avatar
Internets_Ninja
You can also tune the NPP so that it is always open in Track mode, mixed in sport and closed in Tour. Then you don't need to buy a M2W system or pull the fuse. I commonly make this change for my remote tuning clients. It does require licensing the vehicles CCM which is 2 credits.
Old Nov 12, 2021 | 11:53 AM
CrazyKZ-777
Always open actually isn't ALWAYS open, flaps will close in higher speed and low rpm. Are you saying that there is another "tune" way to keep the flaps open? Even if there is, I want to be able to close them when I pull into my neighborhood and I can also start the car with flaps always closed as well. The neighbors appreciate that!
And the strange sound before was always there (flaps open or closed). I do have a M2W switch which I LOVE btw. The only thing that fixed the strange noise was the trans tune. Now it's more power tuned with the shift points and the sound I was hearing totally went away.
Old Nov 12, 2021 | 02:02 PM
miami08VETTE's Avatar
miami08VETTE
Just in case the sound comes back keep in mind that a CAI can cause that sound when shifting gear to gear.
Old Nov 12, 2021 | 05:40 PM
Internets_Ninja
This is EXACTLY what I am saying. There is a computer called the Chassis Control Module that controls the NPP valve functions. HPTuners unlocked the ability to license and tune this computer module a while ago. You can make the Drive Mode/exhaust modes do whatever you want. You can program TRACK mode to NEVER close, I do for many of the clients that install headers. You can make Sport Mode keep the valves open all the way until 6th gear or not. It is completely customizable.
You can also turn off rumble mode when you start the car to keep the valves closed. Personally I just switch it over to Tour Mode before I start the car if I want to keep it quiet. But to each their own. I don't want to deal with another device to control my NPP since I can just make it do whatever I want in the tune.
Old Nov 13, 2021 | 03:06 PM
KemahGT's Avatar
KemahGT
^^^^^This is easy to do if you have HPTuners and the CCM unlocked^^^^^
Old Nov 13, 2021 | 04:27 PM
CrazyKZ-777
I'll keep that in mind, but I already have a Mild to Wild switch. I can open the flaps at will this way. Thanks
To Strange shift sound after tune
