Rev match and temp gauge quit
Several days ago when driving through town (without rev match, A/C, engine temp gauge and radiator fan blowing) I happened to recall an entry I read in a Camaro Forum and switched my ride selector from Sport to Tour,—Voila!—the temp gauge came on. So of course I tried rev match and it worked too. Then I switched it back to Sport and they stayed on. The system seemed to re-set itself when the ride selector changed. No Battery cables needed.
I went into the controls and changed the suspension and steering to align with the ride selector, and it’s been several days and a hundred miles or so and it hasn’t failed again yet. I have turned off the engine sound control too. I’m wondering if having different steering and suspension settings might have triggered this. I’ll post again in a few days to let you know if this hack’s got any legs. It hasn’t gone this long without switching off for a couple of months. Stay tuned.
UPDATE: This post is a week later, 3/16, and after a couple hundred miles, Rev Match, engine temp gauge etc. are still operating normally. I think this is because I went into the controls and ‘synced’ the suspension and steering to be determined by the ride selector **** (I use ‘Sport’) on the console. Mine is a 2014—-I turned the exhaust sound management to ‘off’ a long time ago. The car has not gone this long without this occurrence since this started last October (or thereabouts).
2nd Update: Today is 4/21 and the problem has not re-occurred (daily driver). Again, the syncing of steering and susprnsion tpo the dash ride control **** seems to have done it.
Yet another update: 4/30/23
Absolutely (see Bruno below) was the thermostat—many months and no further issues at all.
I say this in every post about this. It comes up pretty often. People refuse to change the tstat first and think it’s all sorts of other issues.
the c7 causes numerous things to happen when it doesn’t warm up above 170 degrees in a normal amount of time:
ac stops works
Rev match stops working
temp gauge reads 0
fans full blast
you can reset it with a code reader then do it again.
ac stops works
temp gauge reads 0
fans full blast
It seems everyone wants to replace the coolant temp sensor. It's the thermostat people. And, it's not just a bad thermostat causing these symptoms, a lower temp thermostat can cause these issues even when working correctly.
You can't throw a lower temp thermostat in the car and expect it to run as stock. You will have issues, some of which you can tune out.
My original battery lasted 41 months. The 2nd battery lasted 36 months. I don't use any trickle charger.
Questions maybe someone can answer to try to replace other parts?
- Is there a separate engine temperature sensor from the coolant sensor since there are 2 different items for them in the cluster?
- Also where is the ambient air temperature sensor? I've noticed it go to 0 too sometimes.
Bill
The first instance of this being observed, it will not cause the check engine light to illuminate, but the water temperature gauge will drop to 100, the fans will go to full speed, the tachometer engine cold “yellow halo” will be present, and you will lose rev matching. On repeated drive cycles where this is observed, the symptoms remain the same and the check engine light will be on as well.
Yes, a failed temperature sensor can cause this, but in most cases, the real culprit is the thermostat, it is opening too soon, or is not closing fully when the water temperature is below the thermostats operating temperature, causing the engine coolant temperature to rise too slowly and not reach the minimum expected temperature. Obviously, cooler weather tends to expose this issue. Installing a cooler temperature thermostat can also cause this issue.
The difference between actual overheated vs. this failsafe mode is that the temperature gauge will read 100 even when the temperature of the coolant is above 100 degrees. If the engine was actually overheating, the temperature gauge would show the high temp. Note that you can check the engine oil temperature and see that the engine is not overheating. This is also agood check for a stuck open or early opening thermostat as well, if after several minutes of operation, the oil temperature is well below 200 degrees, the thermostat is most likely the cause. In my case, the original thermostat failed after 107K miles and 7 years of operation. Fortunately, it failed this way as opposed to stuck closed.
Once the vehicle is fixed, if the code is not cleared, the temperature gauge will not move off 100 and the cooling fan will be on at full speed until the engine coolant temperature reaches the expected warm engine temperature, then the gauge will reflect the correct temperature and the fan will return to normal operation. Both the thermostat setpoint as well as the overheated engine fan run time and speed after vehicle shutoff are values that can be modified with a tune.
I noticed my temp gage was stuck on 100 after 5 miles of freeway driving. Radiator and hoses were cold. Engine ran well and did not smell hot. The overflow tank was at level and cold.
The local parts store had a new 207 deg stat in stock, so I swapped it out in about 1/2 hr, added a cup? of water and started it up. Temperature gage started moving quickly.
207 deg seems like a odd ball #, but the stock is 194? The temp gage shows about 220. I haven't checked the actual temp.
Well, the temp sensor is electrical and consists of only one part, a thermistor, which are extremely reliable and very rarely fails.
On the other hand the thermostat is mechanical with many parts thats always moving, opening and closing. Thus a higher failure rate part compared to the temp sensor.
When the thermostat fails every thing goes 'wacky', and most people can't believe it is just simply the thermostat. Makes one think there is a very serious problem with all the systems but that is just how the computers software works.
