WaveTrac Diff - Rear Axle Popup
Old Oct 28, 2021 | 10:08 AM
stephen1254's Avatar
stephen1254
Default WaveTrac Diff - Rear Axle Popup
It's been about 8 months since I've read any activity on this issue, so I thought I'd see if anyone has any new ideas.
RPM built a new WaveTrac diff for my Z51 with 4.10 gears 18 months ago. I love the setup but the car throws a "Rear Axle" warning every time it's driven. The dealer has pulled the codes and it indicates a software problem in the Body Control module. This makes sense, as the module is checking the operation of the ELSD, and that no longer exists.
The only suggestion I've seen is to bleed the ELSD system, but that didn't work for me. Has anyone else dealt with this? I'd love to find how someone was able to tune that part of the software out of the system. It evidently requires a special license to access the BCM, and I haven't found anyone that can do that.
Old Oct 29, 2021 | 10:23 AM
dankhts's Avatar
dankhts
any suggestions from RPM re a cure? they must have heard of this before?
Old Oct 29, 2021 | 11:28 AM
stephen1254
They were the ones that suggested bleeding the ELSD. Beyond that they have no ideas.
Old Oct 29, 2021 | 12:44 PM
Jeff V.'s Avatar
Jeff V.
Get in touch with these guys: https://www.whiteautoandmedia.com/
They should be able to reprogram your cluster to disable the rear axle message. The codes will still set, but you won't see the warning on the dash.
Old Oct 29, 2021 | 01:11 PM
CraigStu's Avatar
CraigStu
Not surprising. I think we are at the point where every mechanical change needs to be preceded by a check as to what electronics will need to be re programmed.
Old Oct 29, 2021 | 08:16 PM
stephen1254
Thanks for the suggestion. It looks like these guys may be able to get rid of the warning.
To WaveTrac Diff - Rear Axle Popup
