Monster clutch install question
Old Nov 7, 2021 | 12:55 PM
edsc7's Avatar
edsc7
Default Monster clutch install question
So I pulled my engine to install my 416 stroker , so the monster triple didn’t come with install directions but I’ve installed clutches before with no issues . I bolt it up and put the engine back in. I then noticed a billet spacer which after research is a slave cylinder spacer … idk how I missed it but either way I did. After reading some applications need it some don’t. Hoping someone can chime in and let me know if it’s needed or not .
Old Nov 7, 2021 | 01:15 PM
ss2z06's Avatar
ss2z06
There should be specs for the clutch. On a triple disc there should have been a couple of measurements taken to know if you need the spacer. Measurement from the tq end of the bellhousing to the pressure plate fingers and a measurement from the face of the tq tube itself to the slave fully compressed. Unfortunately without having the slave shimmed to the correct spot you’ll either have engagement issues or clutch wear problems. If I recall the specs are on monsters website.
Old Nov 7, 2021 | 01:18 PM
edsc7's Avatar
edsc7
So the only way to check is pull it back apart. Ok that sucks but rather do it right
Old Nov 7, 2021 | 10:37 PM
ss2z06's Avatar
ss2z06
Im sorry but it’s the only way to measure. I’d contact monster or check their website at this point before pulling back apart but I’d be surprised if they tell you it’s ok.
To Monster clutch install question
