No lights in DIC
Our 2015 Z51, A8, 13000 miles, picked up last Friday from CarMax -
Running some errands just now, and after getting in the car after my second stop, I had no power anywhere to anything. The start button did nothing, power door and hatch release didn't work, DIC and Infotainment screens black. Opened hatch w/key, found negative battery cable could be rotated a tiny bit on the terminal (battery has 2020 mfg date on it). Snugged up the terminal nut w/fingers a bit, and most power returned. The Infotainment screen lit and worked, car started and ran, doors/hatch worked, but DIC stayed dark.
Returned home, tightened nut w/wrench, but no change in DIC. Other electrical seemed to work.
Am I missing something simple/stupid?
(Here's the funny part - my next errand stop when I had the failure was the local Chevy dealership to make an appointment to check everything out. CarMax has a 30-day warranty for any issues, and I wanted the dealer to see what he could find.)
Anyway, is there a reset button or function for the DIC that I should look for, something that might trip in the event of a power interruption?
TIA,
Larry
Make sure that both battery clamps are down and flat - then tighten.
Lower a window before you disconnect the battery so you have an easy way back in if necessary.
You will have to reindex the windows after you reconnect the battery.
GL
Ron
