Tuner Q: Best Tuning Method for Simple Tune Change
I have a pretty much stock '15 Z51. The only major mods to the engine are a Dewitt's Radiator and Fan, and a 170 degree stat. She runs at 168 pretty constantly if the AC is on so the fan runs max. If I turn off the AC, it will run hotter of course because the fan does not run as much.
I wanted to get recommendations for a tune just to change the fan to better match the 170 stat.
From what I read, tuning software like HP tuners can modify the fan table. But I guess there is no single value that can change the stat value in the tune. But I am wondering if there are simpler options I can use to adjust the fan.
I have read that some tuning solutions can turn off AFM, so I could take off the Range I use. So that would be good.
What "Home Use" tuning solution would you recommend by a tuning novice for these two changes, without going to a professional tuner in person.
Thank you in advance.
I think that it will also allow you to set fan speed but am not 100% sure.
Go to their website and look up what the I3 can do.
I use mine just to turn off the AFM.
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
