ISO: EBCM Wiring Schematic
Old Dec 30, 2021 | 08:11 PM
koldnrg's Avatar
koldnrg
Default ISO: EBCM Wiring Schematic
I searched first so I apologize if this is already somewhere else. I need a diagram for the EBCM connector that plugs into the module. I’m repairing a front end hit and this was damaged. I thought I had it good to go but have a RF wheel speed fault and I am unable to program in techline. Thanks in advance for any help.
Old Jan 1, 2022 | 06:19 PM
Bill Dearborn's Avatar
Bill Dearborn
Here is what the FSM has:
Bill
Old Jan 1, 2022 | 09:03 PM
koldnrg's Avatar
koldnrg
Thank you, not 100% sure I understand what’s all there but I will study it when I’m back at the car and it may become clearer. Thanks again.
Old Jan 3, 2022 | 03:32 PM
Bill Dearborn
Found several more that tie into the above schematics.
Bill
Old Jan 3, 2022 | 10:48 PM
koldnrg's Avatar
koldnrg
Thanks a bunch! I’m trying to figure this out. According to your first three diagrams it shows the wheel speed sensors and the steering wheel angle sensor connecting to the ebcm module but I don’t see on the actual pin out where they connect? Do I just use the wire color shown in that sensor? For example the front right wheel speed sensor shows gy/bn and ye for wire but on the connector I don’t see where they come in? I’m probably missing something simple here but I’m trying to learn.
Old Jan 8, 2022 | 09:43 PM
koldnrg's Avatar
koldnrg
Alright so I think the end of the existing harness is too far damaged. I’m gonna roll the dice and splice in new steering and brake control module connectors from a harness i sourced used. If that doesn’t do the trick I will bite the bullet and replace entire engine harness which looks less than fun. Wish me luck.
Old Jan 10, 2022 | 11:34 PM
koldnrg's Avatar
koldnrg
Well replacing the wiring didn’t resolve the issue. I am able to communicate with the ebcm and the chassis modules via gds2 however they both state they are not communicating with each other when you go into the modules.
Additionally steering angle sensor is not talking to ebcm and one wheel speed sensor is still offline but I feel the speed sensor issue is unrelated. I’m pretty confident the engine harness which the ebcm plugs into is good to go now but the harness which runs across the front crash bar may still be the culprit.
I was able to program my used steering module just fine however when attempting to do a replace/reprogram on the ebcm it fails. Reprogram actually finished but didn’t change anything.
ebcm still has the immobilizer fault since programming is unable to complete.
Leaves me with the following possibilities.
- Both used ebcm are bad “yes I have 2”
- chassis module is bad
- Some type of wiring gremlin still messing with me.
Anyone else have any ideas?
Old Jan 11, 2022 | 01:44 PM
Bill Dearborn
Here is another diagram showing the EBCM connector and the connections to the sensors, etc.
Old Jan 11, 2022 | 02:02 PM
Bill Dearborn
Since you are dealing with a bunch of damaged wiring and possible module issues, I am posting the following troubleshooting comments from the FSM.
Bill
Old Jan 11, 2022 | 08:12 PM
laserdude2215's Avatar
laserdude2215
You are being extremely vague and somewhat contradictory - programming completes but it fails! Both cannot be true. It would be much better if you would post the actual diagnostic report that GDS2 provides.
Old Jan 11, 2022 | 10:53 PM
koldnrg's Avatar
koldnrg
Sorry didn’t mean to be vague at all. What happens is if I do a “Replace and Reprogram” on the EBCM it fails to complete after several attempts. I instead went with just the “reprogram” option and it actually completed but did not remedy any of the problems. I will snap a picture of the display next time I’m working on it.
Additionally I checked resistance between pins 12-13 On the dlc and got 120ohms instead of 60ohms so obviously I either have a wiring issue or a bad module somewhere. Main things that pop up on EBCM that I remember are lost coms with chassis module, steering angle module, multi axis acceleration module, and restraint module.
Old Jan 11, 2022 | 11:33 PM
laserdude2215
Check pins 6-14 also.
Old Jan 11, 2022 | 11:35 PM
koldnrg's Avatar
koldnrg
Got that one sorted out, showing 60ohms, when steering was damaged it originally showed 120 and ecm wouldn’t power up. Good to go there now.
Old Jan 12, 2022 | 02:01 PM
koldnrg's Avatar
koldnrg
Pretty successful day, after replacing the entire harness that runs across from crash bar the vast majority of codes related to the ebcm cleared. I am still unable to complete a replace/reprogram sequence but I am leaning more towards my pass through device being the culprit. I’ve read some guys run into issues trying to get by cheap with the vx-nano such as myself. Either gonna fork out the dough for a better tool or bite the bullet and drag her to a dealer and see if they can get it done. Thanks for all of the help so far!
To ISO: EBCM Wiring Schematic
