2016 C7 belt tensioner needs replacing
Old Jan 17, 2022 | 03:44 PM
Leeontherun's Avatar
Leeontherun
1st Gear
Default 2016 C7 belt tensioner needs replacing
Hi,
Just came back from a chevy dealership and was told that the belt tensioner (gm 12686272) needs to be replace due to the whining noise when they were replacing the battery and alternator. I’m just skeptic because I’ve been driving almost 8k miles without problems but I wanted to make sure if it needs to be fix. Attached is the video of the noise. Any feedback is appreciated. Thanks.
File Type: mov
Old Jan 17, 2022 | 08:14 PM
96GS#007's Avatar
96GS#007
Originally Posted by Leeontherun
Hi,
Tried to download the video and get nothing.
If it's squeaking or squealing or whining, then yes.....99% likely it's the tensioner. They also tend to puke fluid and rattle on occasion. Look at the body of the tensioner and if it's covered in grunge, it leaked.
Old Jan 18, 2022 | 07:37 PM
Avanti's Avatar
Avanti
Is it leaking? That used to be reported here as a cause for replacement. I don't recall noting noise related to that, but an "Advanced search" across the C7 sections here should bring up a number of threads. All the best.
Old Jan 19, 2022 | 03:34 PM
Harvey White's Avatar
Harvey White
I have replaced mine twice, first when the original was leaking fluid and the second time when it started to rattle. From other post on this forum, others have also experienced issues with the tensioner. It is easy to replace if you decide to replace it yourself.
To 2016 C7 belt tensioner needs replacing
