Door latch problem
Old Jan 24, 2022 | 10:15 AM
tamsvette's Avatar
tamsvette
Default Door latch problem
I have a 2014 convertible and I got locked in for the first time. Used the cable to get out. Latch seems to be defective. It will not operate with door button or lock/ unlock buttons. Yes the buttons are good and battery in fob and car is good. I ordered new latch asy and it will work with all lock/ unlock buttons except the fob. When you press a button on the fob it seems to cycle but doesn’t do anything. The latch part no is 2289889. There is another latch for the same vehicle # 2289887 with lock control. They both say they will work with my vin. I have called numerous gm dealers and no one can tell me anything. Does anyone have an idea of what “ with lock control” is? Thx
Old Jan 24, 2022 | 10:45 AM
laserdude2215's Avatar
laserdude2215
Your terminology is screwy! Does the external door switch work? How about the internal door switch?
The fob isn't supposed to open the door, so I'm not sure what you are expecting.
Old Jan 24, 2022 | 10:48 AM
tamsvette's Avatar
tamsvette
With the new actuator everything works but the fob! The fob will not lock and unlock the door.
Old Jan 26, 2022 | 04:40 PM
Bill Dearborn's Avatar
Bill Dearborn
Can you unlock the passenger side door or open the trunk using the FOB? Have you walked around the car trying to open things from the rear and the passenger side?
Problems with the remote functions may set body codes but you will need a GM MDI scanner or equivalent to be able to read those codes. An OBD II scanner won't be able to read them.
The lock control is for the AF8 antitheft feature. Your part numbers aren't correct. GM part numbers have 8 characters Vs the 7 you show.
Bill
To Door latch problem
