C7 z51 M7 start up issue
Old Mar 8, 2022 | 01:31 PM
SDVette94's Avatar
SDVette94
Default C7 z51 M7 start up issue
Hey guys, I'm new to the forum here. I recently just bought a 2019 manual Z51. So I'm still getting used to the clutch and I stalled the car with the steering wheel turned and when I went to start it up again it was having a hard time to start I had to start it twice and the 2nd time it started. With the steering wheel straight it starts perfectly fine. The car has 2 months of bumper to bumper warranty left and I have 2 more years of power train warranty. I have made an appointment at my local Chevy dealer to get this looked at.
Anyone ever run into this issue? I also think the dealer probably didnt use 94 octane when they filled up.
Old Mar 8, 2022 | 02:36 PM
ersatz928's Avatar
ersatz928
That's a weird one....never heard of that issue before...and I can't think of a reason why the car would start differently when the wheel isn't straight....
The gas used has nothing to do with this.
Old Mar 8, 2022 | 02:41 PM
SDVette94's Avatar
SDVette94
yeah very odd. I searched the forum to try to find something similar but cant find anything on this.. wonder what the dealer will say
Old Mar 8, 2022 | 03:44 PM
Zjoe6's Avatar
Zjoe6
Never heard of that one but so far I never had to start mine with the steering wheel turned. If the dealer can't duplicate it, they probably won't be able to help much.
Old Mar 8, 2022 | 06:11 PM
CraigStu's Avatar
CraigStu
Any possibility it was something else. My non-Z51 19 w/ M7 has to have both clutch and brake pedals depressed to start it. I guess I must do that automatically most of the time but once I stalled it when the light went green. I was barely costing through the intersection, truck on my butt, pushed in the clutch to fire it and nothing. I had to hit the brake also to get it to fire up. At that speed I came to a complete stop. Not fun.
Old Mar 8, 2022 | 06:20 PM
SDVette94's Avatar
SDVette94
That could be a possibility. I am going to try and see if it does the same thing again today.
Old Mar 9, 2022 | 01:57 AM
SDVette94's Avatar
SDVette94
I tried to re create the start up issue and i couldn't get it to happen again...I do notice that going from neutral to 1st gear isnt smooth. I usually go to 2nd and then 1st gear and its smooth. Anyone else have that?
Old Mar 9, 2022 | 06:17 AM
mdformula350's Avatar
mdformula350
well the M7 cars really start to shift better when fully warmed up.
a few tend shift into 3 and 4 to get things moving and the try to get into first.
or like u mentioned second into first.
also i think i tend to be too gentle when shifting or putting in gear. I dont mean like slam it but something im just not firm enough.
Old Mar 9, 2022 | 09:38 AM
C7&7's Avatar
C7&7
Yes, first and second are real notchy when the transmission is cold. I never try and put the car in first if it's moving, ever.....I will roll to a stop in second or even neutral then come to a complete stop and put it in first.
It's a 19 so you probably didn't have the brake and clutch pressed in together and it started weird.
Enjoy the car, it's fine.
Old Mar 9, 2022 | 12:10 PM
CB56's Avatar
CB56
Change the oil in the tranny and while your at it do the rear end too.
Old Mar 9, 2022 | 12:25 PM
SDVette94's Avatar
SDVette94
Yeah i was gonna tell chevy to do it. Car is at 27,000kms now. Would they put OEM tranny oil in it or can i tell them a specific oil to use?
Old Mar 10, 2022 | 06:20 AM
mdformula350
im replacing my trans and rear end fluids with just factory ac delco. most likely the dealer will only use delco to replace. i highly doubt they will install something else unless you really know them and provide acceptable aftermarket stuff...
Old Mar 11, 2022 | 09:11 PM
Avanti's Avatar
Avanti
Simple enough to check... someplace out of the way (home?), try to duplicate the problem a few times. I'm guessing it most likely won't happen again. All the best, in any event.
Old Mar 12, 2022 | 10:50 AM
SDVette94's Avatar
SDVette94
i tried to duplicate the problem and could get it happen again. all is goood👍🏽
Old Mar 12, 2022 | 10:22 PM
Goat 2 Vette's Avatar
Goat 2 Vette
Get a new battery.
Old Mar 13, 2022 | 11:42 AM
CB56's Avatar
CB56
They probably use oem but it won't hurt to ask.
Old Mar 13, 2022 | 11:43 AM
CB56's Avatar
CB56
To C7 z51 M7 start up issue
