Oil performance
to wit:
.........Billy Godbold, Valvetrain Design Engineering Chief at Comp Cams feels that enthusiasts are seeing something that might be mistaken for pump-up, and is still a problem that needs to be addressed.
“What we are talking about here is the bleed down rate and effective lash (clearance) that reduces the dynamic duration and stability of a hydraulic roller lifter system at high-RPM,” explains Godbold. “While valve bounce can lead to the hydraulic system holding a valve open, there is not an actual mechanism that can accurately be described as ‘pump-up.’ The valve bounces up, and the dumb hydraulic system just adjusts to hold it up for quite a while.”
“While the bleed down rates definitely change dynamic duration, and it changes based on RPM and all kinds of other influences, we have not seen anything that can accurately be described as ‘pump-up.’ The closest thing we have seen on the Spintron is when you go into severe valve bounce,” Godbold reveals. “Unlike with a solid lifter bounce, which has a natural, symmetric parabolic shape, when you have significant bounce on a hydraulic system the inner piston can move up and hold the valve open for as much as an extra 50 degrees of crank rotation. I believe the guys running engine dynos in the ‘70s through ‘90s would see fuel standoff above the carburetors when this happened, and they knew the intake valve was being held open.”
Bill
No. All Synthetic oil is not the same.
