Alignment keeps slipping
Old Apr 11, 2022 | 02:05 PM
Toddster993's Avatar
Toddster993
Default Alignment keeps slipping
I have a 2017 c7 grandsport
the car is at the dealer for its 3rd alignment in 1500 miles. What would contribute to it going out like this?
Old Apr 11, 2022 | 03:43 PM
Bill Dearborn's Avatar
Bill Dearborn
The mechanic isn't tightening the LCA cams to spec. They need to be torqued to the 125 ft-lbs specification and that can be hard to do when squatting under a mid-rise alignment lift. Get some cheap red fingernail polish at a CVS store and after the alignment is set make sure to mark each LCA Cam (8 total, 4 front and 4 rear). Once you have them marked you can tell if they slip. I track my car and make sure the cams are torqued to the proper spec and in 6 years I have never had any of them slip.
Bill
Old Apr 11, 2022 | 04:17 PM
BrunoTheMellow's Avatar
BrunoTheMellow
I curb hop, pull 1.6+ Gs and jump turtles on slicks and my alignment doesn’t slip either. Take your car to a dedicated track shop. They will do a better job on a proper alignment if you tell them what you want.
To Alignment keeps slipping
