Mag ride shocks leaking
Old Apr 14, 2022 | 04:16 PM
KitMolnar's Avatar
KitMolnar
Navigator
Default Mag ride shocks leaking
I have a 2015 Z51 with Mag Ride. Had it in the shop today for basic maintenance, and the tech pointed out that 3 out of 4 shocks were majorly leaking - passenger front enough to coat the lower control arm. I have 35000 miles on the car. Is this a common issue?
Old Apr 14, 2022 | 06:03 PM
Bill Dearborn's Avatar
Bill Dearborn
Hard to say without seeing pictures. GM says some leakage is permitted. They aren't like the standard old fashioned shocks that other cars have. See attached PDF with GM bulleting showing how to judge the shocks.
Bill
Old Apr 14, 2022 | 09:13 PM
KitMolnar's Avatar
KitMolnar
Navigator
Bill
Bill,
Thanks for sending the bulletin - I feel better about having them replaced. 3 were worse than picture 4, so the bulletin would have suggested reacement. Driver side front was probably okay, but if I'm doing 3 I might as well do the 4th!
Old Apr 15, 2022 | 08:15 AM
KitMolnar's Avatar
KitMolnar
Navigator
Thanks for sharing the bulletin Bill. In reviewing it, I definitely have 3 that would be in the replace category - looked worse than picture 4. The drivers front shock is only mildly weeping.
Old Apr 16, 2022 | 09:00 PM
Avanti's Avatar
Avanti
Yes, it's common, and to a degree GM calls it "normal." An "Advanced search" across the C7 sections here will generate a lot of relevant threads.
Old Apr 19, 2022 | 11:11 PM
17WhiteGS's Avatar
17WhiteGS
I have some for sale, not leaking if your interested
Old Apr 20, 2022 | 03:03 PM
KitMolnar's Avatar
KitMolnar
Navigator
Thanks for the offer, but I've replaced them already
Old Apr 23, 2022 | 04:59 PM
Corvette-Dan's Avatar
Corvette-Dan
Default Pm
PM sent about these shocks
To Mag ride shocks leaking
