Injector Cleaner
Old May 12, 2022 | 11:35 AM
Supraman45's Avatar
Supraman45
Default Injector Cleaner
My Corvette mechanic just recommended that I use an injector cleaner to remove any possible buildup on injectors. Car is a 2016 base coupe with 14,xxx miles. He could/would not recommend a brand.
Does anyone have a suggestion?
Old May 12, 2022 | 12:14 PM
miami08VETTE's Avatar
miami08VETTE
I use Techron products. I can only assume it works and no evidence it ruins anything... YMMV...
Old May 12, 2022 | 12:50 PM
Buddhaman's Avatar
Buddhaman
I've always just added a can of seafoam to my tank every so often. I'm planning on doing that soon and then a plug change (77K miles, not sure if they have ever been changed).
Old May 12, 2022 | 03:21 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Techron or BG44 !!
Old May 12, 2022 | 03:37 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Kinda thought the additives to my Shell gasoline cleaned that stuff.
Elmer
Old May 12, 2022 | 04:04 PM
Avanti's Avatar
Avanti
I use the GM brand product once a year at each oil change, as GM recommends.
Old May 13, 2022 | 03:27 AM
TJay74's Avatar
TJay74
The injectors by design dont really get much in carbon build up on them, it is the backside of the intake valves that get the most build up. Those are the parts that injector cleaners cant reach or help remove.
Old May 13, 2022 | 03:20 PM
Rayland's Avatar
Rayland
Banned Scam/Spammer
OP:
Chevron Techron Concentrate plus, complete fuel system cleaner, is recommended by many major carmakers, the world over.
1. Cleans deposits from fuel injectors, intake valves, and combustion chambers.
2. Cleans, restores, and protects the entire fuel system, including sulfur-contaminated fuel gauge sensors.
3. One tankful, can help: maximize fuel economy, restore and protect operation of the fuel gauge sensor, minimize harmful exhaust emissions. Relieve cold start problems, minimize deposit-related knock and ping, and finally, restore lost acceleration.
Note: There are several specific differences between auto mechanics and auto technicians. One key difference is their area of expertise. Auto mechanics are very handy at fixing a wide variety of part in your car. Whereas auto technicians are trained to be able to interact with the computers in your car in order to diagnose the problem.
Note: I have a financial interest in Chevron.
Many thanks,
Ray
Old May 13, 2022 | 08:55 PM
TJay74's Avatar
TJay74
Originally Posted by Rayland
OP:
Many thanks,
Ray
Chevron is good stuff, all I have used for years on my vehicles. Only bad on the DI engines though, fuel injector cleaner doesnt touch the intake valves at all and it also doesnt do much to the injector tips either. Every time I have pulled my injectors out, the tipis still had light carbon buildup on them.
Old May 13, 2022 | 10:07 PM
CavalierKing's Avatar
CavalierKing
Old May 15, 2022 | 12:06 PM
Supraman45's Avatar
Supraman45
Thanks, all!
Old May 19, 2022 | 02:42 PM
Walter Raulerson's Avatar
Walter Raulerson
Use top tier gas
Old May 20, 2022 | 12:10 PM
Widgeon5's Avatar
Widgeon5
On one Techron site appears the caveat to not use Techron more than twice per oil change. That implies to me that despite the beneficial things it does, it is deleterious to the oil in some way. I called Techron and could get no explanation of their recommendation. I started the following thread:
https://www.corvetteforum.com/forums...-caveat-2.html
Be sure to read down to message #28 about BMW Corporation's experience with it.
Old May 20, 2022 | 12:51 PM
spinkick's Avatar
spinkick
I wouldnt think the injectors are what you have to worry about. You run premium fuel with lots of detergents. Its the build up on the valves that techron and gasoline arent touching that is an issue. Run a catch can and hope for the best?
To Injector Cleaner
