Lisle Brake Tool
Old May 12, 2022 | 01:30 PM
MrHix's Avatar
MrHix
Default Lisle Brake Tool
Will the Lisle 29100 Quick Quad Pad Spreader work on the Zo7 CCB calipers?
Thanks,
MrHix
Old May 13, 2022 | 03:07 PM
Bill Dearborn's Avatar
Bill Dearborn
This is what I use:
https://www.amazon.com/Separator-Caliper-Compressor-Spreader-Maintenance/dp/B08NNDX7M8/ref=asc_df_B08NNDX7M8/?tag=hyprod-20&linkCode=df0&hvadid=494939685805&hvpos=&hvnetw=g&hvrand=1595934714927675806&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9009982&hvtargid=pla-1199640977914&psc=1 https://www.amazon.com/Separator-Caliper-Compressor-Spreader-Maintenance/dp/B08NNDX7M8/ref=asc_df_B08NNDX7M8/?tag=hyprod-20&linkCode=df0&hvadid=494939685805&hvpos=&hvnetw=g&hvrand=1595934714927675806&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9009982&hvtargid=pla-1199640977914&psc=1
It works well with fixed calipers although when pressing the pistons into the caliper after the pads are removed you can work with 4 pistons at a time and then do the last two separately. The brake pads do need tabs sticking up from the top of the backing plate to provide a point where the tool can push on the pads.
Bill
Old May 13, 2022 | 08:22 PM
MrHix's Avatar
MrHix
Thanks for the info Bill!
MrHix
To Lisle Brake Tool
