Out Of Winter Blues - Error Codes
Old May 15, 2022 | 11:24 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Default Out Of Winter Blues - Error Codes
Well, got the 17 Z06 out yesterday for it's first drive of the year.. got about 2 miles and it started running rough, then the wonderful Stabilitrak, Service Rear Axle, and CEL flashing. Had to keep the car around 40mph to get it home. Only codes so far are the P0300, but need to grab my good scanner for more in depth checks. Chevy app warning my Emission System & Antilock Braking System... which is nuts.. First time the Z gave me any problems like this. Battery on the maintainer since day one, says good, but battery is 5 years old might not hurt to replace it to be sure. Could be gas is bad I guess as well kinda doubt it tho'.. Will be interesting to see what I find.. sheesh not a good start ... I know others have had experiences with this stuff as well... wish me luck..
Old May 15, 2022 | 11:43 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Good luck.
Old May 15, 2022 | 12:28 PM
MasterDave's Avatar
MasterDave
Moderator
Weak/dead-ish batteries will make the computers on these things go crazy.
Old May 15, 2022 | 12:36 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
This.
Old May 15, 2022 | 01:17 PM
DebRedZR1's Avatar
DebRedZR1
Moderator
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'17, '21
Had similar issues with my 16 ZO6. Also make sure all connections are tight. Sounds basic, but a loose cable also caused me problems. Good luck !
Old May 15, 2022 | 01:18 PM
Gixxerman's Avatar
Gixxerman
Moderator
I am leaning towards battery even tho car starts fine and it's always on a tender. It is 5 years old.. just have a hard time believing something went wrong just sitting in the garage...
Old May 15, 2022 | 02:38 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
0300 is gobs of misfires. Unless a rodent has been gnawing on your wiring, I'd suspicion a battery as a good possibility.
Elmer
Old May 15, 2022 | 03:13 PM
Gixxerman's Avatar
Gixxerman
Moderator
No rodents or anything in the garage fortunately...
Old May 15, 2022 | 04:37 PM
Bill Dearborn's Avatar
Bill Dearborn
Check for loose spark plug wires. The P0300 code can cause the other codes.
Bill
Old May 15, 2022 | 04:50 PM
Gixxerman's Avatar
Gixxerman
Moderator
I will double check all of them ty
Old May 15, 2022 | 04:59 PM
17 Z06/Z07's Avatar
17 Z06/Z07
I have had a battery tender reading good even though it wasnt charging but you said your car start well. How about doing a battery disconnect for 15 mins and see if it resets?
Old May 15, 2022 | 05:16 PM
Gixxerman's Avatar
Gixxerman
Moderator
Good Idea
Old May 15, 2022 | 05:53 PM
17 Z06/Z07's Avatar
17 Z06/Z07
Originally Posted by Gixxerman
Good Idea
Let us know.....GL
Old May 16, 2022 | 03:35 PM
Gixxerman's Avatar
Gixxerman
Moderator
Damn, tested battery 13.7 volts and 765 cranking amps.. she may be 5 years old but it ain't the battery unfortunately..
Old May 16, 2022 | 03:42 PM
jamieo's Avatar
jamieo
31.7 volts
Old May 16, 2022 | 03:51 PM
17 Z06/Z07's Avatar
17 Z06/Z07
alt.?
Old May 16, 2022 | 08:04 PM
Gixxerman's Avatar
Gixxerman
Moderator
Was getting a P0307, so I swapped out coil wire and plug from 7 with 5. Car is back to P0300..multiple misfires. I may just have to drive slowly and just get it to my dealer
To Out Of Winter Blues - Error Codes
Old May 16, 2022 | 08:21 PM
Quick Silver Z
Let me know if you need a ride back home...
Old May 16, 2022 | 08:37 PM
Gixxerman's Avatar
Gixxerman
Moderator
Old May 17, 2022 | 09:04 AM
Zjoe6's Avatar
Zjoe6
Can't you just swap out the bad ignition coil? Looks like you figured out which one it is. The code will tell you bank and cylinder. Just did this on my DD but never did it on my C7. Saved me a trip to the mechanic. $50 for a new ignition coil. Bought a spare for next time.
