AMT Motorsport Sale - 15% off EVERYTHING we make and 10% off all safety gear!!
Old 05-26-2022, 09:15 PM
Mark@AMT Motorsport
Supporting Vendor
Mark@AMT Motorsport's Avatar
Default AMT Motorsport Sale - 15% off EVERYTHING we make and 10% off all safety gear!!
It's that time again folks! Starting Friday morning May 27th and running til Midnight Monday the 30th, every AMT product on our site is available at 15% off when you use coupon code "cfholiday22" at checkout. This is your chance to save some serious coin on big ticket items like our Spherical Bearing Kit and X-Wife Drop Spindles, and will also yield substantial savings on Camber Kits, Spacers, Motor Mounts, Diff Mounts, Seat Mounts - oh my!
Addtionally we're taking 10% off all safety gear. So all Alpinestars and Sparco suits, Simpson and HANS head and neck restraints, Spa automatic fire systems, etc. The safety gear is already discounted in the price and the coupon code will save you the 15% on all AMT stuff. There is a lot of stuff we don't have up on the site, but we have access to the entire Alpinestars and Sparco lines, so if there is something you want that we don't have listed, just send me an e-mail. Same situation with Stilo helmets.
Head to www.AMTMotorsport.com to take advantage of the discounted pricing.
We've listed some of our products below in case you may be unfamiliar with what we do.
C5-C7 Adjustable Camber Kit
The product the launched our company is available for all C5-C7 Corvettes. If your car sees any serious track time than a camber kit is virtually required equipment. Set your alignment once and never worry about it again. Everything is USA made and guaranteed for life.
For more info on C5 and C6 camber kits follow this link. For the C6Z/ZR1 head over here. And to solve problems for all C7s head this way.
Differential Mounts - C5 and C6
Mitigate wheel hop and stop your trans from flopping around during hard cornering with our offerings for the C5 and C6 Corvettes. Rather than knocking off the same product that everyone else has for the last 15 years, we came up with fresh and updated designs to address short comings from competitors. These billet pieces firm everything up without a huge increase in NVH and they are gauranteed for life.
For the C5 check this out and for the C6 check that out.
X-Wife Drop Spindles for C5 and C6
Combine GSpeed design with AMT Motorsport manufacturing and what do you get? The best God-damned drop spindle on the planet that's what! Machined on our 5 Axis CNC, they start out as 70 lbs blocks and wind up as the 6.5 lbs beauties you see before you. Available in plain finish or your choice of anodized colors.
Learn more about the X-Wife by clicking here. (And the first person to get the X-Wife reference gets a cookie)
C4-C7 Wheel Spacers
We offer 4 different sizes of wheel spacers. Our 1/4" spacer uses the lip of the stock hub for centering and can be used with stock length studs. Our 3/8" spacer pushes the wheel out a smidge further but the ring on the hub is no longer effective. We recommend going to the 2.5" ARP studs if you're using a 3/8" spacer. We also offer 3/4" and 1" spacers with a machined lip for centering. These spacers should use the 3.25" ARP studs. ARP studs are available on our website and if you buy a set of spacers and studs, we can install them in your hubs for free. The studs require a press to get in and out so if you don't have one just send us your hubs and we'll tackle the job for you.
For 1/4" and 3/8" spacer head this way. For 3/4" and 1" go that way.
C5-C8 Monoball Control Arm Bushings
If you're looking for slot-car like handling for your Corvette then a set of monoballs is probably the best money you can spend on your car. The car is transformed and so much easier to drive on the limit. We use the best materials available and custom fit each part to your YOUR control arms. All you have to do it send them to us and we take care of the rest, and return shipping is included. For a detailed video on how intensive our process is, check out the video below highlighting the process.
Pricing is $2500-2700 depending on your car, which means you save $375-$405 depending on your setup. That's a whole entry fee for a track weekend people!
Followthis link if you would like to turn your car into a race car.
C5/C6 Vulcan Motor Mounts
These mounts are now on their third variation and better than ever. A single bolt keeps your motor from moving fore and aft, while vulcanized rubber dampens the vibrations so they're not as harsh as solid mounts. We now use a hard anodized 6061 center section to keep the 2 rubber pucks in each assembly where they belong. Make no mistake these mounts do not feel like the pillowy soft oil-filled gushiness of the stock mounts. You are definitely going to feel more of the engine with these mounts, but your 350 lbs lump of a motor will not be moving all over your engine bay either when performance driving.
Follow this link to order yourself up a set of motor mounts
C5-C8 Ultralow Seat Mount
This is the lowest, strongest, safest billet seat mount available for the Corvette. It will put your seat on the floor if needed. Using this mount with the Sparco QRT-R seat I gained almost 2 inches of head room over MTI rails with a Sparco EVO. Our integrated sub belt takes the guess work out of installing your 5 or 6 point harness. Not only that but it will survive an 85G mostly-rear impact. This seat mount saved my life and it can save yours too - just hope you never need to find out!
Follow this link to get yourself low.
C5-C6 Extended Gas Pedal
Our product makes heal/toeing your C5 and C6 Corvette a breeze. It's a cheap and effective mod to increasing your driving enjoyment and I guarantee you'll love it or I'll give you your money back.
To make your Corvette easier to drive at the limit, click here.
Finally, seats from Sparco and OMP are already discounted, harnesses from Sabelt, all BK Harness bars - pretty much every single thing on our site is discounted in some way!
Hope everyone is off to a safe and fast track season. Most of you know I was in a near fatal accident one year ago and I'm happy to say I'm back on track with a friends' borrowed C6 T1 car. Ran 57s last week at Limerock so I'm right back in the saddle. Hope to see you guys on the track this season. Thanks as always for the support!
Old 05-27-2022, 08:44 AM
Mark@AMT Motorsport
Supporting Vendor
Old 05-28-2022, 06:20 AM
Mark@AMT Motorsport
Supporting Vendor
Old 05-29-2022, 11:44 AM
Mark@AMT Motorsport
Supporting Vendor
Old 05-30-2022, 08:51 AM
Mark@AMT Motorsport
Supporting Vendor
To AMT Motorsport Sale - 15% off EVERYTHING we make and 10% off all safety gear!!
Quick Reply: AMT Motorsport Sale - 15% off EVERYTHING we make and 10% off all safety gear!!
