So I bled my brake yesterday and noticed three bleeding valves were corroded with rust. anyone have any good suggestions on an upgrade and where to buy... possibly stainless and corrosion free?
Well looking around they seem to make them. But I am getting/seeing different sizes for the corvette. Either a M8 or M10 ? They also make a special speed bleeder with a ball check built into the bleeder. Now one of these says SS ball and SS spring in a brass housing. But the housing looked zinc plated to me. Maybe just a stock photo. Now these would need covers to keep out any dirt that might affect the ball check valve. They include them. But easy to loose and they sell them separately. You want to get the right size when do this. Maybe some one else will chime in and give the correct size. Looking forward to answers.
I don't know the specs for stock C7 bleeders but, FWIW, I installed Speed Bleeders on my daily driver and find them very helpful. They work exactly as advertised.
After doing many searches... the GM part# is 25900782. But since three of the eight were corroded wit rust... im hesitant to use the OEMs. The thread size is m10 x 1.25 and as far as I can tell... the front valves are the same size as the rear. So I've been searching for m10 x 1.25 in SS... ideally with the "speed bleeder" technology... and not having too much luck... sigh
After doing many searches... the GM part# is 25900782. But since two of the eight were corroded wit rust... im hesitant to use the OEMs. The thread size is m10 x 1.25 and as far as I can tell... the front valves are the same size as the rear. So I've been searching for m10 x 1.25 in SS... ideally with the "speed bleeder" technology... and not having too much luck... sigh
Originally Posted by garyw68
yup... that the best way to go...
I spent some time researching this. The Speed Bleeder site leaves a bit to be desired, with no application listed for 2019 Corvettes. There are, however, listings for earlier C7 MYs (2014-2018). According to their cross-reference, earlier MYs used part numbers "9497K", "14213", and/or "H9497-2" bleeder valves, all of which correspond to SB1010S-SS Stainless Steel Speed Bleeders. I sent an inquiry to Speed Bleeders via email, and will post any response I receive...
Well on the speed bleeders ones I found, only the check ball is Stainless Steel. The Russell and the Edelbrock 639520 only have the ball in stainless Steel. The other take away is do NOT over tighten the screws. Some even say give them a shot of WD40 before you put the plastic cap back on after you are done bleeding them. Let us know what you find and if the size you talked about is correct
I'm not sure at what you're looking. Speed Bleeders are available in Steel and Stainless Steel versions. I haven't dissected them, but I've run the SS version on my daily driven Tacoma for years, and have NEVER had a problem with corrosion.
Agree with your advice to not over-tighten and a litttle WD-40 seems like a decent idea too.
Thanks. A couple of issues, however... First, these are not stainless steel. Second, $41/four is about 45% more expensive than the non-stainless option at SpeedBleeder. Total cost for these from TPS is $82, versus a $63 from SpeedBleeder.
TPS says they have a stainless option priced at the same $15/ea point as SpeedBleeder's, but a search failed to locate them. If available, buying from TPS should be about $7 cheaper, thanks to free S&H.
Ok thanks. I just saw them as an option. Their site is odd. If you buy their stainless lines kit they offer "speed bleeders" for $58.99 for 8. But not sure if they are stainless or zinc coated.
Thank you... looking forward to their response...
I just got off the phone with Whitney from SpeedBleeder...
She confirmed 2019 MY should use the same as previous MYs - SB1010S-SS Stainless Steel Speed Bleeders or SB1010S NON-Stainless Steel Speed Bleeders. She also confirmed their stainless version has stainless steel body and internals, while their NON-stainless version has a non-stainless body with stainless internals.
Vortech347 thank you. I was ready to say these are not Stainless Steel. But after reading everything. You can order them in Stainless Steel too. Not only that but they do polish them. They explained everything but the re-coating of the threads. I am thinking that you have to take the SS Speed bleeder out and re-coat the threads on it. Then it has to dry. Stainless Steel is hard, so you do not want to over torque them and ruin the seat on the caliper.
I had the same thing happen on my Z06 - one of the bleeder valves was rusted. Rock Auto has them and the price is low. I ordered one and it's been sitting in the box for a week or two now along with spark plugs that I'm not looking forward to installing. Never thought about stainless vs other metals; guess I'll find out when I get around to opening the box.
Don't be concerned if you can't get speed-bleeders as you might wish. We've lived without them forever without issue, or at least I can speak for myself. All the best.
