Oil Temp Overheat warning!
Old Jul 15, 2022 | 03:09 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Default Oil Temp Overheat warning!
I was doing Parade laps at Lime Rock Park Northeast Granp Prix and my '16 Z51 gave oil overheat warning and then coolant temps went up !
It was 89 degrees and problem started on third and final lap. I KNOW you are supposed to use 15w-50 for track use but it was only 3 laps though we did hit over 100 mph.
Car cooled down immediately as I was pulling off track and after about 5 minutes I shutdown and fan ran for a good 10 minutes.
Comments please ?
Old Jul 15, 2022 | 06:51 PM
ErnieN85's Avatar
ErnieN85
First thing I did to My 16 Z51 A8 after pace laps at Watkins Glen was a Dewitts radiator, GM radiator was just too small, after a couple more years I went to Their 70 MM racing radiator.
Stock just wouldn't cut it
Old Jul 15, 2022 | 08:57 PM
BPHORSEGUY's Avatar
BPHORSEGUY
So your radiator controls your oil temp? Mine only controls the coolant ?
Old Jul 15, 2022 | 08:58 PM
ErnieN85's Avatar
ErnieN85
Yes, there is a oil to water cooler on all LT1’s so your is also
Old Jul 16, 2022 | 11:29 AM
BPHORSEGUY's Avatar
BPHORSEGUY
Went out again this morning .
78 degrees and I kept the rpms from banging off the limiter.
Oil & coolant never got above 212F !
Old Jul 16, 2022 | 12:22 PM
BrunoTheMellow's Avatar
BrunoTheMellow
Comments please ?
im thinking this was a fluke on the oil temp sensor. Parade laps should never heat up a c7
Old Jul 16, 2022 | 03:31 PM
ErnieN85's Avatar
ErnieN85
No but mine did also with the stock radiator
works fine on the street but quickly goes up even with mild track use
Old Jul 17, 2022 | 10:04 AM
96GS#007's Avatar
96GS#007
Comments please ?
My bad....was thinking transmission temp. Still shouldn't overheat for parade laps.
Old Jul 17, 2022 | 12:44 PM
KemahGT's Avatar
KemahGT
I think the OP said it was high oil temperature not trans temperature.
Old Jul 17, 2022 | 05:19 PM
BPHORSEGUY's Avatar
BPHORSEGUY
I really wish you guys would READ the original post !!!
Old Jul 17, 2022 | 09:41 PM
BrunoTheMellow
Here’s why I think it’s a fluke. As far I know the oil sensor stops reading at 302 degrees which I and some others have hit with no warnings. It takes a while for oil temps to creep up. Coolant temp usually hits first. 3 parade laps is nothing for a z51 what’s your oil level ? I m thinking the sensor messed up momentarily
Old Jul 17, 2022 | 10:03 PM
X25's Avatar
X25
Sr.Random input generator
Comments please ?
The AUX radiator that came standard with 2017+ Z51/GS remedies cooling issues for Z51s. Also, if you used 15W-50, since it's thicker oil, your temps would only go up further, not down.
I personally prefer OEM radiators, and we're lucky to have the 51mm OEM radiator (that comes standard with 2018+ A8 Z06s) as an option, for only $300 shipped. In my experience, it performs just as good as DeWitts' 70mm radiator. DeWitts' design induces much more turbulence (intentionally to increase heat exchange), which I think drops the air flow at high speeds enough to nullify the benefit at track use. I've tried them all, and OEM upgraded one works about just as good at 1/4 price. Your mileage may vary, of course.
To Oil Temp Overheat warning!
