tires
Old Jul 26, 2022 | 05:24 PM
DarrenH's Avatar
DarrenH
6th Gear
Default tires
Anyone running a 305 rear tire on a 2019 stingray
Old Jul 28, 2022 | 10:00 AM
SFwoc's Avatar
SFwoc
for track work, I run Nitto Nt1 305/35ZR18's in the rear on a 2017 Stingray z51. I encountered some rubbing issues against the fender lip when hitting dips in the road (I drive the car to the track on those tires) which went way when I had coil overs installed and a track alignment done.
Old Jul 28, 2022 | 02:40 PM
Duke Slade's Avatar
Duke Slade
8th Gear
I am about to get 305s on a 20" rear, 11 inches wide, 79mm offset. Disappointed
to hear a rub issue.
Wondering if a wider rims (from 10" to 11") would change the offset?
Old Jul 28, 2022 | 03:18 PM
DarrenH's Avatar
DarrenH
6th Gear
I talked with several people that say they fit great .
Old Jul 28, 2022 | 03:21 PM
Duke Slade's Avatar
Duke Slade
8th Gear
Thanks, good to know. I think I will get them.
Old Aug 5, 2022 | 05:54 PM
Duke Slade's Avatar
Duke Slade
8th Gear
Ha, I bought 11" wide rims and 305 tires and they rub like crazy......on 2019 Stingray base 73mm offset but they rub in the middle on the wheel well....anyone want brand new tires and rims???? Going to get my original wheels painted black and go back to stock tires.
bummer.
Old Aug 22, 2022 | 09:36 PM
Duke Slade's Avatar
Duke Slade
8th Gear
Turns out only the left rear rubs, and not too bad, hasn't even worn the sound deadening layer off. But sounds bad...ha, I think they will work just fine.
Old Jan 28, 2023 | 10:28 PM
GT2BHPPY's Avatar
GT2BHPPY
Did the 305s fit on the stock Z51 rims?
Old Jan 29, 2023 | 08:27 AM
DarrenH's Avatar
DarrenH
6th Gear
I didn't put them on the stock rims.
Old Feb 2, 2023 | 09:21 PM
BluRace's Avatar
BluRace
i had 305s on stock Z51 rims and now have different 305s on aftermarket Z06 rims and have not had any rubbing issues at all
To tires
