CCB pad change
Old Aug 10, 2022 | 10:21 PM
the blur's Avatar
the blur
Default CCB pad change
How do you compress the pistons on CCB calipers?
Normally I take a screwdriver and jam it in between the rotor & old pad. Can't do that with CCB's......
Old Aug 11, 2022 | 01:20 PM
9sec's Avatar
9sec
unbolt the caliper and use an old pad an a c clamp to squeeze them back in or a caliper tool. watch that the fluid doesn't overflow the reservoir
Old Aug 11, 2022 | 01:23 PM
the blur's Avatar
the blur
That's excessive work if the rotors don't have too many seasons on them. If I unbolt the calipers, the rotors are getting weighed, and it becomes a major project.
Not to mention they're probably 200 ft-lbs... which I can't do on my back.
Old Aug 11, 2022 | 03:37 PM
9sec's Avatar
9sec
you wanted a way to push the pistons in without wrecking a 6k set of rotors. thats how its done. not sure why you need to be on your back its done within the fender well but anyway weighing the rotors is never a bad thing
Old Aug 11, 2022 | 06:21 PM
SouthernSon's Avatar
SouthernSon
Have used this tool for years on every vehicle I have and have never needed anything else, on or off the car. Simple, direct and easy. No chance of damage to anything unless completely reckless.
https://girodisc.com/caliper-piston-spreading-tool/
To CCB pad change
