"Brakes Worn" Message On CCB GS
Old Aug 17, 2022 | 12:31 PM
MrHix's Avatar
MrHix
Default "Brakes Worn" Message On CCB GS
Is there a specific resistance for the brake pad wiring or is it just an open or closed circuit?
MrHix
Old Aug 17, 2022 | 04:09 PM
Bill Dearborn's Avatar
Bill Dearborn
It is an open or closed circuit as far as the sensors go. However, if one of the four connectors that connect the sensor to the car harness on the cradles or the two connector pins on the EBCM has a high resistance due to corrosion/dirt the EBCM might sense it as an open circuit.
Bill
Old Aug 17, 2022 | 05:05 PM
MrHix's Avatar
MrHix
Thanks Bill, I'm going to try and check as much as I can reach.
MrHix
To "Brakes Worn" Message On CCB GS
By Michael S. Palmer | 2026-06-03 09:39:05
