Fuel questions
Old Aug 17, 2022 | 08:57 PM
Pktrusty's Avatar
Pktrusty
Default Fuel questions
I was hoping someone would provide some expertise. I am having a built 416 12.5:1 compression to run on e85 with full bolt ons. The cam has the +32 lobe. Lt4 hpfp and lt4 injectors give me range on the fuel side or should I go with the dsx low side solution to?
thanks
Old Aug 18, 2022 | 11:00 AM
Internets_Ninja's Avatar
Internets_Ninja
Yes, you will require the DSX low side to support the high pressure fuel requirements of those parts.
