I did a budget brake upgrade. I was able to pick up new CTS-V calipers for $562, and the rotors for $828 off amazon... I painted them to match the factory gray that came on the car;, VHT cast iron is a close match. I will caution anyone who orders Goodridge stainless brake lines, they dont work with the factory hard line brackets. I ended up picking up Factory Z06 lines.... overall a pretty easy upgrade. I also added some T-1 Sways bars I picked up for locally For $40 from a local shop
Sorry didnt see these..... One of the keys to a cheaper cost is to put the amazon items in your cart and let them sit... you will see price drop
Amazon: Calipers: 172-2522/172-2521 .... any CTS-V Caliper works.. and at the time cheaper than the Corvette... same exact Caliper.. same goes for ZL1( I paid $228 and $338)
Rotors: AC Delco 84951566 AC Delco Rotor, they are the same for both sides.( I paid $414 a piece on Amazon)
Brake hoses: Call Chevy Dealer get the C7 CZ06 hoses; ACDELCO1761882/176881 $140
Brake Dust Shields at Rock Auto ACDELCO 23446730 ACDELCO 23446731
Brake Pads: Committed a sin here, I had EBCs but they did not work... I went and got a set from Advanced Auto ... they will likely get changed (but great so far) CWPLTSemi-Metallic Brake Pads - Front (4-Pad Set) Part # PMD1405H
Amazon; Set of 20 Lug Nuts and 1 Key M12x1.50 Closed End Spline Tuner 40mm (1.57") long 7.87mm Shank
ACDelco Professional 18K2108X Front Disc Brake Caliper Hardware Kit with Clips, Pins, and Bolts $26.34
Akata 5MM WHEEL SPACERS FOR CHEVROLET CORVETTE 5X120.65 CB 70.30 BLACK ANODIZED.
