No start issues.
Old Sep 14, 2022 | 03:19 PM
Victor23's Avatar
Victor23
Default Car won't start, doors won't, dash won't illuminate
I went out of town for much longer than I expected to and did not plug in my maintenance charger. My car sat for two months with no activity.
Went out to start my 16 Z06 and couldn't get the door to open. Went in to the hatch and pulled the door release. No start. All I hear is clicking from the door release area.
Plugged the charger in for a day with no luck. I then tried another charger with connectors on the terminals. No luck. Pulled the battery out and charged it out of the car for a day. The battery is showing almost 12.4 volts. The courtesy lights illuminate and bells chime but the door will not open from the inside or outside using the releases. Car will not turn on, no dash lights, no start. Even the glove box won't open.
Tried to jump start it but no luck again..
I took the battery in to be tested. It's testing in the high 700 for cranking amps.
Any ideas what to do next?
I won't fail to keep the charger plugged in next time.
I think I should have posted this in Tech but maybe someone can help.
Thanks Elmer. Problem resolved. I just corrected my post in the Tech forum.
Charged battery until I got almost 12.45 volts. Reconnected everything back up and she cranked.
What really had me puzzled, was why wouldn't it jump start? Maybe I failed to have something tightened properly.
Anyway, all is good here.
By the way, the maintenance charger is plugged in. It will be a while for I can take her out.
Old Sep 14, 2022 | 03:23 PM
Victor23's Avatar
Victor23
Default No start issues.
Old Sep 14, 2022 | 03:28 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Check the 350amp fuse on the positive side of the battery.
Elmer
Old Sep 14, 2022 | 03:29 PM
eboggs_jkvl
Moderator emeritus
Same as I said in tech. Check the 350amp fuse on the positive terminal of the battey.
Elmer
Old Sep 14, 2022 | 03:31 PM
jwmgr8's Avatar
jwmgr8
Call AAA
Old Sep 14, 2022 | 03:33 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
How old is your battery? I thought batteries should be closer to 12.6 to 12.7. Good luck.
Old Sep 14, 2022 | 03:39 PM
Victor23's Avatar
Victor23
Thanks for the quick reply.
I did that by putting an OHM meter across it. I got 2. All terminals appeared to be tight. Everything clean.
The second fuse would be for the starter?
would there be an obvious sign like burnt indications. Sorry if this seems elementary.
PROBLEM RESOLVED!
Not sure if this made a difference but I put the charger back on till I got 12.45 volts across the terminals.
Hooked everything back up. No courtesy lights or bells until I clicked the fob.
I could tell it was acting normal as I was not getting the repetitive clicking.
I double checked all the connectors. My dash was illuminated. Hit the start button. She made music again. Very happy sounds now I'm happy.
Old Sep 14, 2022 | 04:31 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
A FULLY charged battery is 12.66 volts…if your charger can’t get up to this number you should get your battery checked…your 12.4 is about 80% charged.
Old Sep 14, 2022 | 04:53 PM
Victor23's Avatar
Victor23
Thank you. I took the battery to the dealer where I purchase it two years ago. It has a four year full replacement guarantee.
I think it was so dead it just took a while to get it charged. At 12.3 volts it showed over 700 (almost 800) cranking amps. It was tested on analog and digital testers.
I have it on maintenance charge now so hopefully that will top it off.
Need to drive the darn thing but weather is rainy and love bugs are out in the thousands. Floridians know how bad love bugs are.
Next week looking better for a nice drive to the coast.
Old Sep 14, 2022 | 05:05 PM
C5 Diag's Avatar
C5 Diag
Yes, raining here too in Cape Coral…if you ever need some diagnostic work look me up…never take your car to a dealership for diagnostic work…they are pretty clueless…brake change good…diagnostics bad !!
Old Sep 14, 2022 | 05:09 PM
Victor23's Avatar
Victor23
Thank you for the offer. Will certainly contact you.
Old Sep 14, 2022 | 11:06 PM
socal_tom's Avatar
socal_tom
I am a big fan of AAA for road side services and DMV services I have had AAA about 20 years now
Old Sep 14, 2022 | 11:21 PM
Glad you got it up and running again.
Old Sep 14, 2022 | 11:22 PM
Glad you got it fixed. Here is a link to the C7 Tech thread https://www.corvetteforum.com/forums...rt-issues.html.
Old Sep 15, 2022 | 08:20 AM
eboggs_jkvl
Moderator emeritus
When my battery takes a dive like that, I replace the battery.
I make it a policy to hook up my battery maintainer every time I park in the garage.
Elmer
Old Sep 15, 2022 | 09:49 AM
Victor23's Avatar
Victor23
Elmer
Good advice. I have it hooked up now.
Funny how one's mind works or doesn't: I woke up at 5:00am remembering that I failed to reconnect the vent for the battery. First thing I did when I got up.
Old Sep 15, 2022 | 09:52 AM
eboggs_jkvl
Moderator emeritus
Well, the day is going great for you! You woke up this morning and you've already punched your man card!
Elmer
To No start issues.
Old Sep 15, 2022 | 10:47 AM
Maxpowers's Avatar
Maxpowers
Elmer
For the C7 I would replace as well. This car is so nutty regarding having a strong charged battery that a load test doesnt always pick up.
Old Sep 15, 2022 | 10:55 AM
kaplana08's Avatar
kaplana08
I agree after a drain like that dump the battery. Drain like that can damage battery.
Old Sep 15, 2022 | 12:29 PM
Victor23's Avatar
Victor23
Well Elmer, I about lost my man card a few minutes ago. Wife says dogs are acting funny and she hears a weird noise outside. Wanted me to check it out.
I walk around my house and she ask me if I hear that noise. I'm getting hard of hearing from working on cars, shooting, and music so I don't.
Look about ten feet away and see Mr. Friendly. It's about 6 feet long with close to ten rattles.
About left an oil stain in my pants. I let him go since they are getting endangered in my area.
Off topic for sure but funny.
friendly rattlesnake!
