Stabilitrack light comes on during light cornering
Old Sep 14, 2022 | 10:25 PM
FASTOYZ's Avatar
FASTOYZ
Default Stabilitrack light comes on during light cornering
I’m having some issues with my 2016 corvette zo6. When I do some light cornering I will get my stabilitrack light coming on my dash & the computer engages one of the front brakes right or left depending on which way I’m turning. This occurs in touring mode & sport mode & will kick in right at .4 g’s. Tires are at 30 psi & are warm. Ambient temp was 79 degrees. Any guesses?
Old Sep 15, 2022 | 09:53 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I’d be looking at your front wheel speed sensor connectors and look for any pin fitment issues or any other wiring issues…this is only a guess !!…also possibly the multi axis acceleration module…this is only a guess too…I believe that’s what the C7 uses…best thing is to find someone with a scan tool and scan for DTC’s.
Old Sep 16, 2022 | 09:41 AM
FASTOYZ's Avatar
FASTOYZ
I’ll inspect these connections this weekend & see if I notice anything obvious. I don’t have any codes however as I scanned it already. The stability rack light comes on at .4g’s then goes out once it drops below .4g’s. Hopefully it’s just a wheel sensor. I see a trip to the dealer in my future. 😟
Old Sep 16, 2022 | 10:02 AM
C5 Diag's Avatar
C5 Diag
NO, don’t go to a dealership for a diagnosis or a general repair shop !!…99.9% of them are just “parts changers”…find a diagnostic shop or even an auto-electric shop in your area if you can find one…I see you are north of Portland…give Ken Van Damne Automotive a call in Portland…503-278-5549…ask them if they do testing with an oscilloscope…they “say” they do “state of the art” diagnostics…if they don’t use one they are NOT “state of the art” !!…I do state of the art and I’m just a DIY’er…LOL !!…I think the steering angle sensor is also one of the imputs for the Stabilitack system that may need to be checked.
Old Sep 17, 2022 | 10:44 AM
BrunoTheMellow's Avatar
BrunoTheMellow
What tire sizes ?
Old Sep 17, 2022 | 11:18 AM
FASTOYZ's Avatar
FASTOYZ
Originally Posted by BrunoTheMellow
What tire sizes ?
factory sizes front & rear. Problem also seems to be intermittent as it worked flawlessly last night when I drove it. Frustrating. Inspected the wheel sensor wiring this morning & nothing looks damaged or chaffed.
Old Sep 17, 2022 | 11:45 AM
C5 Diag's Avatar
C5 Diag
You can’t figure out what’s wrong by nothing “looks” damaged !!…that’s not how you diagnose what’s wrong…like I mentioned you have to remove the connector at the sensor and look for loose terminals…I don’t know what electrical skills you possess or the tooling you have so I won’t get into that right now…the short sensor harness that comes out of the wheel hub flexes when the wheels are turned and that is when you are having your issue that is why I was saying it “could” be a wheel speed sensor…without at least a scan tool and a DVOM you’ll only be guessing…and I don’t like to guess.
Old Sep 17, 2022 | 01:13 PM
FASTOYZ's Avatar
FASTOYZ
My approach is start with the easiest which in this case is looking for a frayed wire where something has been rubbing, because if I find that I can most likely save a lot of time & effort troubleshooting other things. Now yes it is time to move on to the next step. I have a scan tool but it is not throwing a code, rather the stabilitrack system seems to be stepping in prematurely basically just doing it’s job just not when it’s suppose to. As far as electrical experience I do happen to be an electrician by trade however I don’t own an oscilloscope. I’m not sure any of that will do me any good as long as it continues to work flawlessly. I need to drive it more to let the problem either develop or get a better idea on what conditions make it fail.
Old Sep 17, 2022 | 01:33 PM
C5 Diag's Avatar
C5 Diag
Don't know what kind of scan tool you have but if it can "graph" your speed sensors while driving you may be able to see a glitch in the signal...with the right scan tools you can observe those sensors along with the steering angle sensor and multi axis sensor...these may also be a cause...without any DTC's set it may be difficult to diagnose.
Old Sep 21, 2022 | 01:20 AM
tsin's Avatar
tsin
Cruising
Use the GM GDS scantool or an Autel scanner to read the ABS code, it will tell you which wheel speed sensor is sending out of range values. It is most likely caused by a loose connector where the wheel speed sensor harness plugs into the chassis.
To Stabilitrack light comes on during light cornering
