Trans/Diff Fluid Change upgrade?
Old Sep 19, 2022 | 08:03 AM
Josue Rodriguez's Avatar
Josue Rodriguez
Default Trans/Diff Fluid Change upgrade?
delete
Old Sep 19, 2022 | 08:14 AM
GOLD72's Avatar
GOLD72
Opinions will vary regarding the transmission but I am pretty certain from long experiences with C6 and C7 cars that the factory fill OEM fluid for the differential is DEXRON LS as the best. DEXRON LS was formulated and introduced as the factory fill in all corvette differentials starting with MY2009. It pretty much stopped the highly problematic low speed turning noise with the clutch plates grabbing with the old Mr Goodwrench fluids in the models prior to 2009. I have difficulty recalling anyone complaining on the Forum regarding their cars with the DEXRON LS installed either as factory fill or as a drain and refill maintenance fluid. I no longer have an A8 auto tranny and never did a fluid change on it while I owned it.
Old Sep 19, 2022 | 09:02 AM
Tinkertech's Avatar
Tinkertech
Only use Mobil 1 Blue Label ATF in the A8 transmission or you will have shutter issues.
Old Sep 19, 2022 | 01:48 PM
Josue Rodriguez
link to specific one and how many QTs
Old Sep 19, 2022 | 05:18 PM
Bill Dearborn's Avatar
Bill Dearborn
The GM-recommended fluid for the diff is P/N 88862624 and its available through Amazon.
Amazon.com: ACDelco GM Original Equipment 10-4034 Dexron LS 75W-90 Gear Oil - 32 oz : Automotive Amazon.com: ACDelco GM Original Equipment 10-4034 Dexron LS 75W-90 Gear Oil - 32 oz : Automotive
I didn't get quite 3 quarts back in after I drained it. I also purchased this small quart bottle pump from Amazon, it made it a lot easier to get the fluid in the diff:
https://www.amazon.com/gp/product/B000BQW5LK/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000BQW5LK/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Sometimes the Amazon links in the forum will upset antivirus programs so if that happens to you copy the link and open a different browser window to use it.
Bill
Old Sep 20, 2022 | 08:37 AM
Tinkertech's Avatar
Tinkertech
If your changing the ATF fluid from the old version to the new fluid, Mobil 1 Blue Label, you will need 24 quarts to do a complete change.
There is a TSB on this subject and a lot of threads on this site too.
Old Sep 21, 2022 | 01:53 AM
dcova's Avatar
dcova
The Mobile 1 Synthetic LV ATF fluid is part number: 124715. This is the new blue label reformulated ATF fluid
For the differential gear oil, many forum member us Mobile 1 Synthetic Gear Oil 75W-90. It contains the limited slip friction modifier same as the ACDelco gear oil product.
Old Sep 21, 2022 | 04:26 PM
Bill Dearborn
If you have the eLSD diff you don't need the friction modifier since there are no clutches in the diff they are external to the diff and have a separate lubrication system.
Bill
To Trans/Diff Fluid Change upgrade?
