Engine code C0800 HELP!
Old Sep 30, 2022 | 02:25 PM
70stingray14's Avatar
70stingray14
Default Engine code C0800 HELP!
I need some help please
Engine Code C0800
The stabilitrak starts freaking out - and now, the gauge cluster shows Brake-ABS and Lost traction,. I replaced the battery and alternator from the dealership. After reading others posts Car is a 2014 M7 with 20k miles.
Thank you!
Old Oct 1, 2022 | 02:17 AM
Bill Dearborn's Avatar
Bill Dearborn
You have a charging system fault of some sort. Here is the diagnostic procedure for the C0800 code. This is taken from the 2016 FSM but it should be applicable to your car.
Bill
Old Oct 1, 2022 | 04:19 PM
70stingray14
Thank you Bill!
Ill start doing some diag.
Carlos
Old Oct 17, 2022 | 04:15 PM
70stingray14
I found the issue. it was a corrosion on the screw that holds down the Oil Catch Can. Super easy fix!!!
Old Apr 25, 2023 | 04:16 PM
Blackwater0323's Avatar
Blackwater0323
I experienced something similar. I lost power steering and got all kinds of codes. Turns out I installed my catch can as recommended on the main ground strap bolt for the steering. I moved the catch can with a modified bracket to the front of the cylinder head.
Old Apr 26, 2023 | 07:32 AM
Tinkertech's Avatar
Tinkertech
When installing a catch can you need to move the ground to the adjacent grounding bolt.
This will prevent all grounding issues.
Old Apr 26, 2023 | 09:59 AM
Flattman's Avatar
Flattman
Originally Posted by Tinkertech
When installing a catch can you need to move the ground to the adjacent grounding bolt. This will prevent all grounding issues.
I wasn't having any problems that I'm aware of but did this last night to be safe.
To Engine code C0800 HELP!
