Bolt-Ons + Tune Reliability??
Old Oct 11, 2022 | 02:36 PM
rsjandu's Avatar
rsjandu
Default Bolt-Ons + Tune Reliability??
Hey yall, I have a Z51 Stingray and I've been going back and forth on deciding on installing bolt ons like headers, air intake, etc because I'm worried about their effects on the reliabilty. I know I will have to tune my car (as my previous posts have shown me lol) so I will definetly lose out on any warranty I have. I daily drive my vette so I just wanted to see some opinions from people more experienced with these cars. How much will bolt ons with a tune affect the reliability? The specific bolt ons I've been looking at include long tube/mid length headers, cold air intake, throttle body, and an intake manifold (maybe). I already have a catless x pipe installed. Thanks!!
Old Oct 11, 2022 | 05:18 PM
JasonVette's Avatar
JasonVette
It might run better. Unless you boost your car it'll be just as reliable especially with mild bolt ons like you're doing. Just make sure you get a good shop and tuner.
Old Oct 11, 2022 | 09:38 PM
robert miller's Avatar
robert miller
Default ttt
OP on your question here you can put on LT headers better air box and even a bigger T,B, without having the car tuned. I did all of this to my car & it didnt chg nothing other than lean the car out now. My plugs before putting parts on it was BLACK car runs rich,, After these parts it ran a little better and chg the color of the plug to more a tan color.
But to get the use of those parts YES you will need a good tuner & get full use of them. Robert
Old Oct 12, 2022 | 07:39 AM
Internets_Ninja's Avatar
Internets_Ninja
If you don't want to tune the car, you will get the best results with Midlength Headers and a BMS drop in filter.
Old Oct 12, 2022 | 08:53 PM
aklim's Avatar
aklim
I wonder about that. How does it run rich if EFI controls the mixture?
Old Oct 12, 2022 | 09:32 PM
^&right's Avatar
^&right
Long tubes, X pipe, CAI, cat delete here about 4 months ago. Gained near 40 rwhp and torque. Told my tuner I would not sacrifice one bit of drivability or reliability, I didn't want lights flashing at me after work was done. Zero issues until a month ago after a day of romping on it my CEL came on. Called my tuner, he said bring it in.
It was a fuel trim that needed a slight adjustment. Said when I was driving it hard I exceeded the variance the computer can add or pull to its programmed trim(15% either way IIRC). He took 10 minutes, adjusted the trim level and no problems since. I have an outstanding tuner who is in it for the long haul and wants happy customers. If I had a bad tuner I would not be happy at all. So its been more than worth it to me. I'd do it again. Promises me he can do the same with forced induction. Authorized A&A dealer to boot.
Old Oct 12, 2022 | 09:41 PM
aklim's Avatar
aklim
Who is it?
Old Oct 12, 2022 | 11:14 PM
Dcasole's Avatar
Dcasole
Put 53,000 miles on my 2015 ported intake , headers, high flow green cats and tuned on LT1 , also had the A8 trans tuned , love the power gain along with the better shifting . I drove it almost daily and did not hesitate to jump in it and take it on a long trip . Plus put many trips down the drag strip ...
3 months ago added a procharger and a new street tune , I am almost at 57,000 miles now, still drive it to work everyday and absolutly would not hesitate to take it on a trip ....
Bolt ons and a tune , if done right will not reduce the reliability. Do your research when buying headers as the as some do have fitment issues , AHR , Kooks fit great , I got a deal on coated Hookers and the only issue I had was my green cats hit the tunnel plate . Some spacers solved my issues
Good luck and let us know how it works out
Dave
Old Oct 12, 2022 | 11:33 PM
Avanti's Avatar
Avanti
For a daily driver, leave it well enough alone... no codes, nothing untoward. Other than long-tube headers the rest is mainly good for bench-racing. All the best.
Old Oct 13, 2022 | 04:40 AM
Internets_Ninja
With a good tuners and properly installed parts. You can get a nice kick in the pants while keeping stock drive-ability by doing , Aftermarket Intake/filter, Ported 87mm TB, Ported LT1 intake manifold, Long Tube Headers with cats and X pipe,(or mids if you want it as quite as stock, as you can retain the factory mids), and a Flex Fuel sensor. No CEL's, no changes in drive-ability. I tune this setup all day long.
You will lose a little bit of city MPG, mostly because you will want to stomp the gas lol.
Old Oct 13, 2022 | 12:45 PM
Adir Hassid's Avatar
Adir Hassid
My gs has headers an e85. best decision made. car should come like this stock
The car loves it, it runs so much better
To Bolt-Ons + Tune Reliability??
