What Should I Expect
Old Nov 16, 2022 | 07:52 PM
K1600GT's Avatar
K1600GT
Default What Should I Expect
I have a reputable engine builder assembling my engine. Gen V Lt4 dry sump set to 20 psi boost. New GM aluminum block, GM race bearings, Callies Magnum crank, Callies Ultra Enforcer Rods, Diamond 2k pistons, stage 1 BTR cam. Cam phaser locked out 100%, AFM delete. What type of documentation should I expect when I pick up the block? One concern I have is when builder said he had to bend the oil squirters so they hit the wrist pins. I thought the oil squirters were too remove heat from the bottom of the pistons. Another concern was that he had to modify the lower cam gear sprocket to fit the magnum crank. Thoughts??
