Idle Rattle
0:19 you can hear it go away as the revs fall, but it comes back once at idle. Engine is at full operating temperature fresh off the freeway.
It doesn't appear to be temperature related.
It's intermittent, but seems to happen 80+% of the time.
It either isn't happening or is drowned out by engine noise once moving.
Coasting in neutral at 20mph or higher I cannot hear it -- could be drowned out by road noise.
Most audible inside the car.
Difficult to hear from above the car.
Impossible to hear over the injector clatter from under the car (if it was even happening while I was under it).
Right now I'm torn between an exhaust leak at the head and direct injection noise -- though, if it's the DI, that's easily the loudest DI system I've heard, diesels included.
Thanks gents!
Two things I'd work to rule out, first is belt tensioner and second torque tube. Both are RPM sensitive.
Belt tensioner is an interesting one. Perhaps the belt flapping around at low RPMs? I do recall reading that they were failure prone.
Went on a short drive tonight after taking apart the airbox to check the air filter. Potentially new behaviour -- the rattling sound will very suddenly and abruptly go away sometimes, now. Usually it would fade in and out, not start/stop abruptly.
In my mind that rules out ignition or injection events, which rules out exhaust leak. It also rules out rotational items, such as the belt drive.
I'll have to put it up in the air and take a good look around the firewall. Might just be some kind of tube or loom not strapped down, rattling against the firewall.
So strange.
https://www.youtube.com/watch?v=4_ZT6HQSryY
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
It's still doing the weird abrupt start/stop behaviour.
Starting to notice what I would describe as excessive driveline slack, not sure if it's related. The car can't idle in first or second gear at this point (or ever? Can't remember), it will start bucking violently if you try.
My findings in the meantime...
The sound is happening at 17hz. The engine spins at 10 to 10.8hz at idle (600-650rpm), and it also continues to be audible when the engine is spinning at 22.5hz (1350 rpm). When at 1350rpm, the sound is still happening at a rate of 17hz, which means it is not tied to RPM. We can reasonably assume it's not injection, ignition, belt drive, or valvetrain related.
It happens with or without the clutch pushed in, which reasonably eliminates the torque tube internals.
It stops happening as revs are falling, but picks back up when ignition events start happening again.
My only thought at this point is it is an engine mount or something related to the physical motion of the engine.
The car is CPO and this is an issue that only happens when the engine is on, so my argument is that it is drivetrain related. Hopefully they don't try to gouge me with diagnostic fees and the like -- I've cleared dropping it off for evaluation and no pricing or charge approval was discussed, so things are looking good on that front.
More to come.
