Key fob not detected?
Old Dec 8, 2022 | 11:15 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Default Key fob not detected?
Why all of a sudden I get this popping up on the screen when i try to start the car? I have to remove the key, and insert the fob into the steering wheel column slot, and then will start....BOTH key fobs are doing this....pulled the fob battery, and it tested 2.95 volts......will a drop of .05 volts stop it from working?
Old Dec 8, 2022 | 12:02 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Replace the fob batteries. Yes, even that small of a voltage drop will cause issues.
Old Dec 8, 2022 | 12:51 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Change the batteries.
ELmer
Old Dec 8, 2022 | 02:01 PM
RonC7's Avatar
RonC7
New battery should be above 3.25 volts.
Just replace fob battery every 3 years and don't worry about it.
Ron
Old Dec 9, 2022 | 06:26 AM
mdformula350's Avatar
mdformula350
yes, just had to put in a new battery in mine. the battery that came out read 2.9 volts and wouldnt work.
i put the older battery in my ford truck fob and it works fine still. lol
again another superior win for gm!
Old Dec 11, 2022 | 10:15 PM
Avanti's Avatar
Avanti
I too found a very slight fob battery voltage drop was a problem. Check all new batteries before insertion, as well.
Old Dec 4, 2023 | 02:09 PM
magnoman's Avatar
magnoman
Getting 1.10v (6 &14 )
Pin 2 60 ohms.
Old Dec 4, 2023 | 02:26 PM
magnoman's Avatar
magnoman
Just tried another battery for the hell of it same thing.
have lights go to open door red door light flashes wants does nothing.
Old Dec 4, 2023 | 06:59 PM
eboggs_jkvl
Moderator emeritus
Pin 2 60 ohms.
3.2v, if less and it won't work.
Elmer
Old Dec 4, 2023 | 07:00 PM
eboggs_jkvl
Moderator emeritus
A new thread on a new trouble would be helpful.
Old Dec 4, 2023 | 07:45 PM
magnoman's Avatar
magnoman
Fixed ,
check the voltage at terminals by fuse box only had 5v ….
loosen battery terminal by fuse box positive and negative retightened problem solved…
went crazy for days trying to track this down. I have no idea why removing the rear positive battery cable make this happen bud whatever.
Old Dec 4, 2023 | 09:17 PM
eboggs_jkvl
Moderator emeritus
Um, 12v battery, FOB battery. I'm a tad confused as to the topic and the problem. Glad you got it fixed!
Elmer
To Key fob not detected?
