C7 rolling screen
Old Dec 18, 2022 | 12:03 PM
rshervey's Avatar
rshervey
2nd Gear
Default C7 rolling screen
Any help to reset ? Car has 1080 miles on it .. went to drive and screen rolls .. and flickers .. it’s not a loose wire .. the car is basically new .. and in heated dry storage no mice into car
What is the reset ? Or suggestions ? The dealer just wants big $$ to just explore
Old Dec 18, 2022 | 03:16 PM
Bill Dearborn's Avatar
Bill Dearborn
Not sure why you think a new car couldn't have a loose wire. That is more likely than one that has some miles on it and the loose wire was found while the car was under warranty.
You need to find a scanner that can read GM Body codes and scan the car for codes. Not all codes generate a warning light. Sometimes all you have to tell you there is a code is something that isn't working correctly. Look for a GM MDI2 or equivalent. Amazon carries some that are Chinese Clones. The units plug into the OBD port but are controlled by GM software loaded on a PC so you need the MDI2 unit and the software along with a Windows PC.
Bill
