I did my cold air intake last week and I brought my car to corvette center in CT to do my American racing headers and catted x pipe. My car has 19k miles and they said my plugs are black like charcoal. What would cause that? I trust them and they do great work and I’m not questioning them but just wondering the reasoning how they would get like that with a car in stock condition
#1 you can't read a plug by just pulling it out of the head , you have to make a hard pass , let off gas , and shut motor down ASAP #2 , LT direct injection motors from the factory run rich , as evidenced by the black tail pipes
If it's running good , all 8 look the same , don't worry about it . Just take it out and run it hard once in a while
Dave
On top of that, if you are using pump gas, because of all of the additives oil companies put in pump gas, trying to use spark plug readings to determine air:fuel radio is a fool's errand.
And the "black tailpipes" people see? They're totally useless as a measure of whether or not the engine is rich or lean. If you look at a calibration file from any direct injected engine in a Corvette, you be surprised that DGI engines run more lean that port-injected, throttle-body-injected or carbureted engines.
