Rear Shock Torque Specs
Old Jan 20, 2023 | 04:43 PM
Trog's Avatar
Trog
Default Rear Shock Torque Specs
So, I've search here & general web. I'm seeing quite a range of #s,
I expect the lower bolt to be high. I have plenty of C5 & C6 FSMs and this is in line:
What I've seen is: 107, 118 & 162. (all Ft Lbs.)
However, the UPPER bolts are NOT that big & most of the places show what I feel is too much:
What I've seen is: 22 which seems right but a TON of places, including here show 74 ft lbs... pretty sure those little bolts won't take that.
Anyone with a C7 FSM handy that could post a pic of the rear suspension torque page.
TIA!
Old Jan 20, 2023 | 04:55 PM
Brad Larsen's Avatar
Brad Larsen
Lower bolt (1) on each shock is 118 ft lb. Uppers (2) are 74. They take it just fine. Good luck!!
Old Jan 20, 2023 | 05:27 PM
Trog's Avatar
Trog
Just finished, I stand corrected. Those upper bolts are way bigger than what I remembered.... 74 was piece of cake. Although, front upper was barely tight from the factory.
Old Jan 22, 2023 | 06:35 PM
Bill Dearborn's Avatar
Bill Dearborn
Not sure which Suspension you have so here are the applicable FSM Pages:
Bill
To Rear Shock Torque Specs
