Drivers side fuel tank removal
Old Feb 13, 2023 | 03:15 PM
tymerr's Avatar
tymerr
Default Drivers side fuel tank removal
Looking for procedure for removing drivers side fuel tank?
Old Feb 13, 2023 | 10:59 PM
laserdude2215's Avatar
laserdude2215
Piece of cake:
  1. Disconnect the negative battery cable.
  2. Drain the fuel tank.
  3. Remove the left rear wheelhouse liner.
  4. Remove both mufflers.
  5. Remove the transmission.
  6. Remove the fuel tank filler pipe bracket.
  7. Disconnect the fuel pump jumper harness.
  8. Disconnect the fuel feed hose.
  9. Remove the left side underbody side rail cross brace bolts.
  10. Remove the left side underbody side rail cross brace.
  11. Remove the left side fuel tank strap bolts.
  12. Remove the left side fuel tank strap.
  13. Disconnect the crossover tube from the left side fuel tank.
  14. Remove the fuel tank.
Old Feb 14, 2023 | 08:25 AM
Catfish4818's Avatar
Catfish4818
Wait...I don't see the cake. Where is it? Did I miss it?
Old Feb 14, 2023 | 08:33 AM
ErnieN85's Avatar
ErnieN85
That is because it's not about 20 hrs by the book
Old Feb 14, 2023 | 02:42 PM
CB56's Avatar
CB56
You don't get cake. After all that crap, you're too tired to eat it.
Old Feb 16, 2023 | 10:18 PM
tymerr's Avatar
tymerr
I was hoping I wouldn't have to remove any of the drive line. Looks like its going to wait a bit longer.
Old Feb 17, 2023 | 06:08 AM
ZO6LIFE's Avatar
ZO6LIFE
It lists as 14 hours labor.
Old Feb 17, 2023 | 12:06 PM
sammy burks's Avatar
sammy burks
Active Streak: 90 Days
Originally Posted by laserdude2215
Piece of cake:
Does the Manual & AT have same procedure for removing drivers side fuel tank
Old Feb 18, 2023 | 03:33 PM
ChiTownVetteTech's Avatar
ChiTownVetteTech
The procedure is to remove transmission for either auto or manual, but can be done without removing the driveline. You do have to remove the frame and lower the driveline as low as you can to get your arms above the trans and remove the crossover pipe. Which I think disconnecting that pipe is the hardest part. They’re always stuck together.
Old Feb 19, 2023 | 08:45 AM
Factoid's Avatar
Factoid
My god, may this never be in my future!
Old Feb 20, 2023 | 08:52 AM
Bpkost's Avatar
Bpkost
I did my manual. I removed tank strap and cross member brace that's it. It's a little bit of a reach to disconnect crossover pipe but doable
Old Feb 20, 2023 | 11:44 AM
Jeff V.'s Avatar
Jeff V.
To Drivers side fuel tank removal
