QuickJack 7000
Old Feb 17, 2023 | 02:16 PM
Midwest815's Avatar
Midwest815
Cruising
Default QuickJack 7000
I came across a good deal on a slightly used Quick Jack 7000, still waiting to hear if it's the extended version or standard. If it's the standard length, by looking at the website comparing it to the 5000, it appears this would work for my C7? I'd like to be sure before spending the cash
Old Feb 17, 2023 | 04:12 PM
BELVIN20's Avatar
BELVIN20
I have one of the first 7000 Quickjack so it is not a extended version, however it works on my 2016 Z using the jacking pucks. Keep in mind the the 7000 QJ is longer than the QJ 5000
Old Feb 17, 2023 | 07:59 PM
Midwest815's Avatar
Midwest815
Cruising
Thanks for your input. Evidently this is a model BL7000SLX, which according to the website is the same length but the newer TL model raises a little higher. The website also says there's 3/4" difference in length between the 5000TL and the 7000TL. Hopefully more folks chime in. It's a great deal but I hate to spend the money and have it not work out.
Old Feb 17, 2023 | 08:23 PM
laserdude2215's Avatar
laserdude2215
Originally Posted by Midwest815
Evidently this is a model BL7000SLX.
I have this exact model. It is very heavy, but it works great.
Old Feb 24, 2023 | 01:03 PM
discopig's Avatar
discopig
I also have the BL-7000SLX and I use it for my 2017 GS all the time. It's perfect.
Old Feb 24, 2023 | 02:34 PM
Spike66's Avatar
Spike66
Do these units, regardless of capacities, work with a side exhaust C2?
Old Feb 26, 2023 | 06:39 AM
Mick_01's Avatar
Mick_01
I have been using this exact model since March 2020, for use with a 370Z and a '19 GS. The fit is perfect for the GS. I bought a set of the QJ wall hangers to get the lift out of the way when not in use. It is a bit heavy, as someone already said, but manageable.
Old Mar 5, 2023 | 06:51 PM
^&right's Avatar
^&right
I don't see why not. They come with 2 different height rubber blocks. You simply put these under your jacking points which would also gain height between the QJ and your sidepipes.
To QuickJack 7000
