RPM Guage Not Working Help!
Old Feb 28, 2023 | 10:32 PM
Gman's 14's Avatar
Gman's 14
Default RPM Guage Not Working Help!
My rpm guage is not working even though all the other guages are working perfectly. Scan tool gives me P0335 which says crankshaft position sensor. I've replaced the sensor but no change. I've inspected the reluctor wheel and its in perfect condition. I've checked and rechecked all grounds. I've gone thru the wiring and the crankshaft sensor plug and have no issues with either. I've checked all fuses and relays but all are good. I've changed the fuse box but no change. If anyone has experienced this issue any help would be much appreciated.
Old Mar 1, 2023 | 12:08 AM
squirrelchew's Avatar
squirrelchew
you still have the P0335? if so, wiring issue or ECU fault.
Old Mar 1, 2023 | 07:11 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What do you mean by “I’ve gone through the wiring” ??…have you ACTUALLY checked this Hall Effect sensor at least with a DVOM ??…a visual inspection is not the way to diagnose this…the sensor has a power (5 volt ref.), ground, and signal wire…was the sensor replaced with an OE one or aftermarket ??
Old Mar 1, 2023 | 08:05 AM
Gman's 14's Avatar
Gman's 14
The sensor was replaced with a OE sensor. The sensor has been checked with a dvom and the 5v reference is good along with the signal and ground wire.
Old Mar 1, 2023 | 08:29 AM
C5 Diag's Avatar
C5 Diag
How exactly did you check the signal wire and ground ???…what was your procedure ??…if all three were checked the car should start if the sensor was good…are you using a scan tool ??
Old Mar 1, 2023 | 01:11 PM
Gman's 14's Avatar
Gman's 14
I checked the signal wire and ground with a test light. The car will start but runs rough because it needs a crankshaft sensor relearn. My scan tool will not do the sensor relearn because there's no rpm showing up on the scan tool. Scan tool thinks the car's not running because of no rpm's.
Old Mar 1, 2023 | 02:22 PM
C5 Diag's Avatar
C5 Diag
You would check the "low reference" (ground) with a test light connected to battery positive or with a DVOM less than 100 millivolts cranking or running...you wouldn't however check the signal wire with a test light though...if your scan tool shows a CKP "counter" and it increments up during starting and running you can assume the ECM is receiving a signal from the sensor...doing a "bypass test" would also let you know if the ECM was receiving a signal...whether it is receiving the proper signal is another story...the ECM is expecting to see the sensors digital square wave go from 5 volts and then ALL THE WAY to ground as it passes a reluctor tooth...without chasing your tail with this I'd find a diagnostic shop in your area that has a scope and let them scope that signal wire...below is my CKP signal which is a 24 tooth and which uses a 12 volt feed...BTW not doing a crank relearn will not cause the rough running...the relearn just recalibrates the cam-crank relationship and also makes the accuracy of the crank sensor since it is the ECM's misfire monitor more accurate.
24X Crank 1X Cam
Old Mar 1, 2023 | 02:25 PM
C5 Diag's Avatar
C5 Diag
If the car is at least running the ECM is receiving some type of signal from the sensor.
Old Mar 1, 2023 | 04:04 PM
Gman's 14's Avatar
Gman's 14
Yes it run's but does have a "long crank" before starting.
Old Mar 1, 2023 | 04:07 PM
C5 Diag's Avatar
C5 Diag
A “long” crank time can also be a cam sensor…without a scope you’re only guessing !!
Old Mar 1, 2023 | 06:11 PM
Gman's 14's Avatar
Gman's 14
I replaced the cam sensor at the same time i did the crankshaft sensor. On a side note, if i pull the ecm relay while the car is running, the rpm guage will jump up to 5 or 600 rpm and then fall back to 0 as the engine is shutting down.
Old Mar 1, 2023 | 06:20 PM
C5 Diag's Avatar
C5 Diag
Which number relay is this ??
Old Mar 1, 2023 | 06:28 PM
Gman's 14's Avatar
Gman's 14
Originally Posted by c5 diag
which number relay is this ??
#61
Old Mar 1, 2023 | 07:05 PM
C5 Diag's Avatar
C5 Diag
#61
Do you mean mini relay 62 (ECM) ??…Im looking at Alldata and Mitchell but for a 2015…trying to find it !!
Old Mar 1, 2023 | 07:11 PM
Gman's 14's Avatar
Gman's 14
Yes it's a mini relay but it's # 61 ECM in my 2014
Old Mar 1, 2023 | 07:20 PM
C5 Diag's Avatar
C5 Diag
I can’t find any type of “ECM Relay” in the Powertrain Management wiring section…do you have a pin out for this relay ??…I looked in both the OE and redrawn wiring…can’t see any ??
Old Mar 1, 2023 | 07:30 PM
Gman's 14's Avatar
Gman's 14
#61
To RPM Guage Not Working Help!
Old Mar 1, 2023 | 07:41 PM
C5 Diag's Avatar
C5 Diag
I can see the fusebox relay but I need to see the pin outs for the 4 terminals of the relay and where they go…I will look tomorrow !!
Old Mar 1, 2023 | 07:47 PM
Gman's 14's Avatar
Gman's 14
OK, what exactly do you need to see from me?
Old Mar 1, 2023 | 07:50 PM
C5 Diag's Avatar
C5 Diag
Actually nothing unless you have the wiring diagram…all relays have 2 power feeds (control and load side) and 2 grounds.
