Front Crank Seal Leaking
Car runs fine, so I pop the hood to check for an oil leak and it appears the front seal is leaking pretty good.
I'm gonna do a leak down and compression test but its running fine and I cant tell any difference in performance.
Blow-by is non existent at idle and when revving it up.
The oil is clean and normal color.
The cars details are as follows.
Procharger P1 kit with a canned tune.
Kooks long tube headers and x pipe.
It does NOT have any crankcase venting mods other than what Procharger tells you to do.
I know the tune isn't designed for the headers and x pipe.
I just haven't got around to getting a custom tune done yet.
Its always run fine but I've never really hammered it hard. Until the other night
on my way home
before I parked it. So I'm thinking there was some piston rattling going on, un seating the rings that gave it excessive momentary blow-by and it pushed out the front lip seal.
I guess I'll know more after the compression test and leak down test. But a new front seal is in order in any case.
These lip seals are not as hardy and resistant to excessive blow-by as the Gen 4 (LS-3) seals from what Ive read.
I had a crankcase catch can on my 02 SS Camaro with a P1sc and never had an issue. I wanted to put one on this engine as well but, again, I just didn't get around to it.
If I'm lucky I didn't damage the ring lands and can just replace the seal and get it tuned.
Have you guys had good luck with the Gen 4 front seals in the Gen 5 engines?
Probably wouldn't even need to use anything but the OEM seal as long as the crankcase is vented properly OR as long as the Tune is spot on.
In any case it is what it is for now until I know more.
Have any of you run into this with the LT1 front seals?
Good luck!
I would do a compression check and if all is good, I would put a breather setup on it. If the motor is hurt you should still put a breather setup on it after you get the issue fixed.
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
