Changed battery now nothing works
Old Apr 8, 2023 | 07:54 PM
SCbarber's Avatar
SCbarber
Default Changed battery now nothing works
Just changed battery in my '17 Z06. Now the doors won't unlock to open, windows not operating. Using the fob it will unlock and lock but that's about all, where do I start? Disconnecting battery and reconnecting did not do anything. Glove box is locked so can't get manual out.
Old Apr 8, 2023 | 08:17 PM
RonC7's Avatar
RonC7
Inspect your connections at the battery - the clamps on the battery posts should be pushed down and level, then tightened. If you disconnected the buss bar sections on the positive terminal, double check that the sections are making good contact and that the bolt is tight - others have had this issue.
If all is good, check for 12 volts dc on each side of each fuse on top of the battery back to the negative battery post. While you are at the negative post, verify that the small black wire is still connected to the cable clamp - this won't cause your problem, but is important for charging system operation.
There are links in C7 General | Sticky Notes to download a PDF copy of the owner's manual.
GL
Ron
File Type: pdf
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Check the 350A fuse on top of the battery.
Also, the biggest failure on battery replacement is the reconnection of the cables. THey must be exactly aligned as they were originally AND they must be clean and tight.
Also, verify that the thin black wire on the negative cable is still attached. They get broken during battery replacement and cause issues.
Elmer
Old Apr 8, 2023 | 11:08 PM
Jims Z06's Avatar
Jims Z06
Did you use a memory save plugged into your obd2?
my cars I plug into OBD2 then other end on a 9 v transitor battery to save all the functions
Old Apr 8, 2023 | 11:25 PM
RonC7's Avatar
RonC7
You don't need any such device for a C7. Typically only the windows need reindexed after power is reapplied. Radio presets and info system settings are preserved when the battery is disconnected.
For those that need emissions inspection, the sensors show NOT READY until the car is driven for a while.
Ron
Old Apr 9, 2023 | 09:43 AM
Internets_Ninja's Avatar
Internets_Ninja
Don't forget to tighten the fuse block side and the little black wire. This issue pops ups often on here with people changing their own battery and then nothing works. Aside from you getting a totally dead new battery, you probably didn't reconnect everything. The Corvettes require more than just a positive and negative cable to the battery.
Old Apr 9, 2023 | 03:20 PM
SCbarber's Avatar
SCbarber
Thanks for the replies. All solved, bad connection with the red wire. Even the windows worked when connection was good.
To Changed battery now nothing works
