drain plug thread pitch
Old Apr 9, 2023 | 08:54 PM
^&right's Avatar
^&right
Default drain plug thread pitch
Looked in the stickies, did not find it. What is the thread pitch/length to a dry sumps oil pan bolts. Want to put magnetic ones in when I do my oil change soon. Thanks!
Old Apr 10, 2023 | 12:33 AM
RonC7's Avatar
RonC7
M12 -1.75 (1.75 threads per mm). Takes 15 mm wrench. It has an integral seal.
This is a common oil drain plug for many GM cars...
Ron
Old Apr 10, 2023 | 09:40 AM
GeoGS's Avatar
GeoGS
Most auto parts carry them. Call before going. A lot of them on Amazon as well. I have 2 them installed as one two piece magnetic for the oil filter. The oil filter magnetics was stronger,(might pinch your fingers) and expensive compared to the 2 plugs. But it is larger and covers a greater area then the plugs. I was worried it would slide off and get lost. But that has never happened. Over 15K and never moved from oil change to oil changed. Still a bit hard to get off. When I find the information on it I will send it to you.
Old Apr 13, 2023 | 07:23 PM
^&right's Avatar
^&right
Thank you gentlemen
To drain plug thread pitch
