Here are the instructions. Note that the fuse locations have been numbered differently over the years. Service of the fuse in a physical location has not changed. For example, the EXH2 (NPP) fuse number is #41 (2014), #42 (2015 - 2018), #87 (2019).
I think he is talking about the fuses on top of the battery in the rear.
It’s pretty straight forward. Disconnect the negative cable first and pull it out of the way (good idea to insulate and restrain as you do not want it making contact with the battery terminal while you remove the old fuse plate. Then remove the fuse plate. Reverse order.
