Shudder location
Old May 12, 2023 | 12:13 PM
Ramets's Avatar
Ramets
Default Shudder location
How do you discern where the shudder is coming from? Transmission or Torque Tube????????
Old May 12, 2023 | 12:26 PM
jwmgr8's Avatar
jwmgr8
Well my 2016 they replaced the Torque Converter and it did not solve the shudder, They did Triple Flush and it went away. GM determined bad fluid.
Old May 12, 2023 | 01:04 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
Yeah, There are a lot of problems with those 8 speeds.. there's even a class-action lawsuit against GM for all the 8 speed tranny problems... There are several GM technical service bulletins out about tranny issues, for dealers to try certain things to fix it.. There's some about the dealer re-programming the TCM/tranny control module with some new GM TCM programming updates regarding that shudder... There are also some programming updates for other things like tranny slipping, clunking, etc.. Another one is for dealers to drain all the tranny fluid out and replace with new, different tranny fluid...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old May 12, 2023 | 02:56 PM
Oskee's Avatar
Oskee
Veteran: Marine Corps
Took my then new 2017 Z06 to the dealer for the shudder. On the test drive as soon as it was placed in manual mode the shudder went away only to return as soon as it was placed back in drive. They did the triple flush only for it to return in 2 years later.
Took it back to the dealer which was a mistake because sitting on the show room floor was a brand new 2019 ZR1.
Guess which C7 I drove home ? Yep the ZR1
Old May 14, 2023 | 07:42 AM
Ramets's Avatar
Ramets
So, there's no permanent fix??
Old May 14, 2023 | 08:59 AM
Tinkertech's Avatar
Tinkertech
Your clutches in the converter may be worn out.
Maybe they didn't use Blue label Mobil 1 ATF.
I'd have it triple flushed again with Mobil 1 Blue label.
Old May 15, 2023 | 03:25 PM
Oskee's Avatar
Oskee
I was told that whoever did the first transmission flush that it was not done right and did not follow the tsb procedure .
Old May 15, 2023 | 09:04 PM
Factoid's Avatar
Factoid
Good, so they gave you full trade in value and you walked…err…drove away happy!
To Shudder location
