Rev Limiter setting
Old Jun 24, 2023 | 03:41 PM
MBrianB's Avatar
MBrianB
Default Rev Limiter setting
What is the rpm setting for the rev limiter on 2019 GS? Not launch control limit.
Old Jun 24, 2023 | 06:03 PM
JaysonP13's Avatar
JaysonP13
2025 C7 of the Year Finalist - Modified
I believe 6500.
Old Jun 24, 2023 | 08:29 PM
96GS#007's Avatar
96GS#007
It’s 6500 or 6600. I’ll peek at the programming when I get home
Old Jun 24, 2023 | 10:58 PM
96GS#007's Avatar
96GS#007
6600. The "Extreme Cutoff" is 6700 but it's kind of a second line of defense. If someone does something to get around the 6600rpm fuel cutoff, the Extreme Cutoff goes to work. In other words, you have to change the cutoff in 2 locations.
You'll also note there are other cutoff parameters such as Engine Oil Temp (EOT)...ie it's not just a single number like the old days.
Old Aug 20, 2023 | 11:13 PM
MBrianB's Avatar
MBrianB
is there going to be damage hitting the limiter? Once, twice, several times?
Old Aug 21, 2023 | 12:49 AM
96GS#007's Avatar
96GS#007
Depends on circumstances.
Old Aug 21, 2023 | 03:37 PM
Lux's Avatar
Lux
If there's nothing wrong with your engine then no. As long as you're not over spinning the engine in an M7 by downshifting too early. Auto cars won't let you money shift.
Old Aug 21, 2023 | 04:57 PM
vader86's Avatar
vader86
Generally no, I've hit the cutoff several times.
Car doesn't like it when you hit it, you'll know you did.
Old Aug 27, 2023 | 12:43 PM
fatsport's Avatar
fatsport
I hit it twice in this lap, front straight in 3rd gear, back straight in 4th. Doesn't hurt anything, it's there to protect the engine not hurt it.
To Rev Limiter setting
