Is this everything needed for a cam?
Old Jul 6, 2023 | 02:33 AM
Juju2002's Avatar
Juju2002
Default Is this everything needed for a cam?
https://www.americanmuscle.com/comp-cams-corvette-stage-1-lst-227-238-hydraulic-roller-master-camshaft-kit-mk224-300-13.html
is this everything i need for a cam + tune ?
if not , is there a full kit i can find?
Old Jul 8, 2023 | 10:26 PM
bradNTx's Avatar
bradNTx
Not even close, need gasket set, head bolts, crank bolt. I'd put a timing set on it if you have any miles, might as well since you are in there. I'm sure others will chime in but to be honest I think you need to do a bit more research on what it takes to pull the heads and swap the cam. Oah and to answer the other question look at Texas Speed's website.
Old Jul 9, 2023 | 07:46 AM
Dcasole's Avatar
Dcasole
Just put the blower on it and call it a day ....
Dave
Old Jul 10, 2023 | 08:59 AM
Travlee's Avatar
Travlee
he is in Cali... going to hard to smog if he tunes it
Old Jul 10, 2023 | 11:15 AM
Dcasole's Avatar
Dcasole
Procharger comes with a 50 state tune on a Diablo .... it does not make as much power but it makes enough ...
Dave
To Is this everything needed for a cam?
