Intake manifold upgrade
Old Jul 14, 2023 | 04:33 PM
Ol Vette's Avatar
Ol Vette
Default Intake manifold upgrade
Hey guys I have a question for all you motor guys out there. I have a 2017 automatic Stingray, convertible with the STOCK intake manifold.
My question is......Is it worth while to upgrade to something other than stock? This is my daily cruiser, not raced, or track or anything.....just to the car wash. How about the throttle body? Can I use the stock one. Any preferences out there that you guys would recommend?
Thanks in advance.....
Ol Vette
Old Jul 14, 2023 | 05:49 PM
Lux's Avatar
Lux
No not if you don't do the rest of the supporting mods to let the engine breath better.
Old Jul 14, 2023 | 06:36 PM
Ol Vette's Avatar
Ol Vette
Thank you for the advice...
I really appreciate your time to answer me
Old Jul 14, 2023 | 07:40 PM
Dcasole's Avatar
Dcasole
You can have your intake ported and it's worth 20 hp but like it is stated above , unless you do other mods like headers and a tune it's not worth it
Ported Throttle body = 0 gain
Dave
Old Jul 14, 2023 | 09:14 PM
Ol Vette's Avatar
Ol Vette
Thanks Dave......appreciate it
Old Jul 16, 2023 | 09:19 AM
Internets_Ninja's Avatar
Internets_Ninja
GM Performance Intake, Ported stock TB and ported LT1 intake manifold is worth a noticeable bump in power. Especially if you get it tuned. Otherwise, it's not worth doing on its own. All of those mods work together to make it viable.
Old Jul 16, 2023 | 12:18 PM
squirrelchew's Avatar
squirrelchew
and with all of the above it's only burning money if you aren't really doing anything with the car. it'll cruise the freeway just as well as a base model Corolla.
Old Jul 17, 2023 | 10:12 AM
^&right's Avatar
^&right
I bought a ported intake, had it installed and retuned. I have Holley CAI, 2" headers and X pipe. I was making 440/440 rw with that. Bought an Edgy Vette intake per the recommendation of my tuner. He'd done the $1k++ Intakes on other LS/LT engines and said they just aren't worth the money unless you are building really big numbers. The edgy Vette was ~$350 so I did that. Had fun installing it, easy to do. Took measurements against the OEM manifold. There was at most .030" difference in the runners, about .020" in the intake port. Very minimal. It was obviously done and done well. I'd wager my bets it was done on a CNC, it was very uniform.
Tuner expected I might get 15-20hp. He worked on it for 2 hours. I got 2hp/2tq. That is smaller than the difference between days of the week and much less than between two different dyno's.
Save your money.
Old Jul 17, 2023 | 06:03 PM
Dcasole's Avatar
Dcasole
Originally Posted by ^&right
I bought a ported intake, had it retuned. I have Holley CAI, 2" headers and X pipe. I was making 440/440 rw with that. Bought an Edgy Vette intake per the recommendation of my tuner. He'd done the $1k++ Intakes on other LS/LT engines and said they just aren't worth the money unless you are building really big numbers. The edgy Vette was ~$350 so I did that. Had fun installing it, easy to do. Took measurements against the OEM manifold. There was at most .030" difference in the runners, about .020" in the intake port. Very minimal. It was obviously done and done well. I'd wager my bets it was done on a CNC, it was very uniform.
Save your money.
Sometimes the gain can be hard to measure on a dyno , its not about gains at the top as much as it is gains across the whole rpm band ... I have an Edgy Vette ported intake manifold and i extensively test before and after every mod I do , logging DA outside temps , track temps and data logs . I also use launch control to reduce variation . My car will pop a 1.7 60 foot on factory run craps and unprepared track time and time again , When my car was NA , my ported manifold was worth 2 tenths . I think it was a good investment
Dave
Old Jul 17, 2023 | 06:53 PM
^&right's Avatar
^&right
Dave
Thanks for posting this, you brought up a great point I missed while posting. I did gain ~10 hp midrange and it did bump my peak RPM by about 750 rpm. Peak HP didn't change, but midrange did. Thanks for sharing this!
Old Jul 18, 2023 | 10:10 AM
squirrelchew
This is literally what a dyno is designed to measure. Saying it's hard to measure it is kind of odd.
Are you instead trying to say that peak numbers are not indicative of actual gains?
Old Jul 18, 2023 | 11:29 AM
Dcasole's Avatar
Dcasole
That's exactly what I am saying ......
So many people are hung up on peak numbers , sometimes you have to look at the gains over baseline under the peak .
Take headers for example, it's well known that headers and a tune will give you 30 -40 HP gain ..... people say they are not worth it ... but if you look at the graph on most of these, the gains start well below the peak and carry up to the red line. This is why headers really give you that seat of the pants gain that you can feel and measure ..
The same goes for the ported intake ..... pair them together and its a good gain .
Also dyno numbers are just that , numbers. It's a tool that you can use to measure gains but different days , different dynos , different operators can all produce different results .
The 1/4 track does not lie , that's where the numbers meet the road and is the true measurement of power
Dave
Old Jul 18, 2023 | 12:25 PM
squirrelchew
Dynos don't lie either? I still get the impression that you're trying to say power under the curve is difficult to measure with a dyno.
Old Jul 18, 2023 | 01:08 PM
Dcasole's Avatar
Dcasole
Look I don't want to get into a debate with you , I am well aware of what a dyno can and cant do ... what I am saying is PEOPLE are not looking at the power made under the curve....
Dave
Old Jul 18, 2023 | 04:10 PM
squirrelchew
well, at least we arrived at what you meant to say in the first place. makes sense! people are dumb.
Old Jul 18, 2023 | 04:20 PM
Dcasole's Avatar
Dcasole
It's because I was being a little more politically correct than you .....
Dave
Old Jul 18, 2023 | 04:31 PM
squirrelchew
Dave
I wasn't aware that saying objectively incorrect things and then backpedaling to what you actually meant to say, which was an entirely different thing, was a form of being "politically correct"
Today I learned!
Old Jul 18, 2023 | 05:03 PM
Dcasole's Avatar
Dcasole
Today I learned!
Squirrelchew from your previous posts i have learned that you always have something to say ... so i dont feel the need to explain to you anything ... and I really dont care if you learned anything or you feel like it's backpedaling ...
What I do care about is "^&right" knew exactly what I was saying as you can see by his post above and as do many others that take my advice ....
Now, let's stick to the OP questions as stop worrying about what I have to say 👍👍
Dave
Old Jul 25, 2023 | 05:44 PM
Avanti's Avatar
Avanti
I hope others have already said, "Don't bother and save the time, money, and potential hassle."
To Intake manifold upgrade
