Yesterday the check engine light came on my 16 corvette had it checked out and the code was cylinder #8 misfired 256 times, not sure if it is a coil, spark plug or plug wire has anyone else had this issue?
Without some specialized diagnostic equipment you’ll have to swap the coil pack, plug, and wire one at a time to another cylinder and see if the misfire follows to that other cylinder..I’m sure many Corvette owners have had misfires so your condition isn’t unique…if not a secondary ignition issue you’ll have to look at fuel or mechanical.
